DefQon
- Jan 14, 2011
Does it still offer the pinpoint 3d imaging with the HD800 and also make them sound more smoother/warmer?
Depends on the tubes you roll.
Anyone have internal picture of the current production MkVI+? (the one with 1/4 TRS moved to the front)
I know Little Dot moved the single-ended headphone out to the front, just not sure if there's any changes to the internal.
Like this?
Looks more like a modified model since the screw holding the balanced headphone output are silver not black. Have not seem any like this on Ebay.
Looks like they jumpered into the balanced output lines for the 1/4 headphone jack so the internal picture should look mostly the same.
"Does it still offer the pinpoint 3d imaging with the HD800 and also make them sound more smoother/warmer?"
Originally Posted by alota /img/forum/go_quote.gif
well if my memory is good, the soundstage was fantastic.
about the sound, this depends on the tubes that uses
Like this?
The amp can drive the HE-6 no problems.
Totally agree. It is the best amp I heard so far with the HE-6, and I tried quite a few, including vintage receiver, T-amp, EF-6 and Shiit Mjonir.
Huh! Wonder if any of the ground loop issues were solved with the 1/4" TRS in front. On my unit, it was basically unusable as a result of the humming.
Although I thought the MKVI+ did well with the HE-6, I still think it didn't have quite enough voltage swing. I did think it did better than the Mjolnir however.
I kind of miss this little unit. Great headphone amplifier.
I don't think anyone has had the mkvi+ factory upgrade, with the caps and wiring, available with new purchase only. I haven't heard anyone mention SQ and would be interested to know how SQ is affected. I would have thought that silver wiring would make an even more neutral sounding and not as enjoyable as a tube amp? Since my speaker set up uses the mkvi+ as a preamp and modifies SQ in a strikingly realistic way over the system minus the mkvi pre I can't see much point in any mods for me personally. The fact that the mkvi does this is surprising given it is a humble headphone amp yet improves detail and sound over a proper speaker amp, (nuForce icon-2), which admittedly doesn't extract all the detail that, say a Trends Audio Bantam Gold does, however I find it much more musical, but it wouldn't be the same system without the mkvi pre in the setup.
