kellzey
- Apr 21, 2011
Is there a straightforward set of instructions in English or an English version of this?
The F3 button on your keyboard should bring up the search list on ulilith.
Why I cannot bring search list up with F3 button![]()
F3 on uLilith didn't give response both in Windows XP nor Windows 7 but bring up Windows default search folder when I used with FN key button.
But of course I don't want to use Windows search folder instead of uLilith self function. I do want playlist search likes on Foobar2000 with its CTRL+F search function.
There is an english version of uLilith on http://www.project9k.jp/download/uLilith/
Hmm, while on the playlist you can add a query to narrow your playlist. An example would be putting artist and then typing SID. Your playlist will then display all artists with the word SID in it. You can later remove the queries if you want to see your whole playlist. I hope that helps as a substitute for search funtcion.
Can I use reclock with the lilith player? Thanks.
so anyone compared uLilith to jplay? I was told that its "beach" mode sounded great, and that you can integrate it within foobar too.
I'm still utterly impressed by uLilith's SQ in 64bit float, it's pure bliss through ASIO4ALL. And the latest builds support automatic VST latency compensation so you can use linear mode EQ's w/o any audible glitch![]()
