- Dec 27, 2010
Hi-one of my problems with LH/Geek Out is the difficulty getting information, basic manual/help kind of stuff. I know it's out there, but I search their site, google,, to no avail. My issue is: I just got the Koss ESP-950 as part of my pre-holiday shopping frenzy. It comes with it's own amp, and I have the GO Special Edition connected to my PC. My recollection is to use it as line out, you have to max the volume on the LH volume control, then hook into the 47 ohm output. Well, at first I got the worst sound you have ever heard from headphones, the music played, but warbled. Then the music player crashed, the GO disconnected itself (only time I've ever felt it cool while connected, and had to reboot the computer to use JRiver again. I thought the headphones may be faulty, so I connected them to my (also new toy) Pono, and it sounded great. I've been searching for what I did wrong, would love to be able to listen to the GO/PC, can't find the information. Anyone know where to find it?
Welcome to the world of e-stat headphones. Don't mind the e-stat crinkling "fart" when you put the headphones on your head/move them on your head. lol
http://wiki.faust3d.com/wiki/index.php?title=ESP/950_Electrostatic_Stereophone
Says here that the E90 amp only has an input level of 1 VRMS, which is well below what the Geek Out outputs at maximum volume (assuming the GO SE is 450 mW like the GO 450, it outputs about 2.68 VRMS). You're probably hearing clipping.
Interesting that the input level is only 1 VRMS. The entry-level STAX amp (SRM-252S) has a maximum input of 30 V.
No idea what the Pono outputs because that player screams in agony with the lack of any specifications whatsoever.
Pardon my cluelessness...I'd think if I were clipping, turning the volume down would help. Does this mean the 950 and GO won't work together?
(As an aside, there my be no info on Pono, but it's designed by Ayre, and, my initial impression is.....sounds mighty good!)
