BenF
- Jan 22, 2013
I think with the Pono set to come out by the end of the year, they must have felt pressure to have a portable item to market. I think they have a point, Neil Young's push on the Pono may make other players that are not iPhones or other phones irrelevant, in a mass market kind of way. Even the way they are going about it, as a sonic upgrade to your existing phone, suggests even now they are hesitant to take on the Pono directly, but still feel they need to have something out there to purchase while a lot of people are signing up for Pono.
As I mentioned, got the Geek Out, love it, think delays relate to the above issues noted, also quality control which seems to be fabulous, item is a small bit of green audio jewelry. I can't believe how light this thing is. When the package arrived, couldn't believe anything was in it!
Documentation is poor-I'm not a techie, confused about the 2 outputs, 0.27 ohms and 27 ohms. What do I use when? I've just been doing it by ear, changing back and forth, stick with the one I like the sound best out of. Also not sure about the settings-you install drivers, get an app, tells you to set Geek as main out. Does this mean speakers should be plugged into it as well? (my sound is out on my speakers, but that is a different issue, had it before Geek arrived, works through JRiver, but not if I listen on internet, say on Youtube. I believe I developed the problem when I upgraded JRiver from 16 to 19.
I think the 0.27 ohm output is the headphone out and 27 ohms is the line out - it is supposed to be connected to an amplifier, which typically has much higher impedance.
