FYI, the Geek Wave XD128 has some serious free perks: Only 3 days left!!!
lots of free perks if you can get in on the XD128 including free memory upgrade to 256k. They do have a payment plan. I hate to see someone on the fence miss out. I think this is an awesome deal.
Hope you can join in.
1 day ago
STRETCH GOAL ACHIEVED!
Wow! Are you kidding me? We've already surpassed our second stretch goal of $333,333! That didn't take long.
As promised, we've unlocked a very special $38 perk: Standalone DAC capabilities for Geek Wave 32, 64, and 128. If you've selected one of these models, you might want to add this very special feature.
Remember, Geek Wave X 128 and XD 128 already have this feature. If you've chosen one of these models, there's no need to contribute to the new perk.
Gavin Fish
1 day ago
GEEK WAVE XD128 FREE UPGRADES
For those of you that have purchased the Geek Wave XD128 and have chosen to add the IEM package, we've decided to add a Gain Switch at no extra charge. Switching between pristine IEM output or powerful big-can output allows you to pair your Geek Wave with every set of headphones in your collection.
Once again, this upgrade is
FREE for those who have chosen to pair their XD128 with the IEM package.
But wait, there's more!
We're also including the SUPER-QUIET shunt regulator for the Femto Clock in every XD128. With residual noise reduced to less than 3uV, this makes the Geek Wave XD128 the first portable player in the industry to feature this power supply circuit.
FREE for XD128 backers!
In order to implement the new circuit into Geek Wave XD128 we needed to free up valuable PCB space. The most logical option was to re-work the original Femto clock package and turn it into a smaller more efficient one. This will be the same Femto clock that's used in the other Geek Wave 32/64/128.
Also, by joining the Femto clocks into the same package, we were able to reduce the necessary Femto Clock minimum order quantity from 150 to only 90!
PERFECTING PERFECTION? YES WE ARE!
Introducing the Dedicated Audio Device (DAD) upgrade perk
The Geek Force has spoken! Many of you have asked for the “ultimate” version of Geek Wave and we're happy to accommodate, and just in time for Father's Day.
This perk applies to backers of the Geek Wave XD128 ONLY!
With this perk you'll have your XD128's CPU upgraded and fine tuned to Larry's ultra specific specifications, literally doubling the core numbers and putting Geek Wave on par with devices you'd normally see in the $5,000+ range.
- Minimum Phase Digital Filter: Removes all the pre-ring that's caused by the digital filter to make every note in your music much more natural and smooth.
- Smart 1.5M Up-sampling: When playing back 44.1K/48K CD Quality music, this will automatically trigger a two stage up-sampling algorithm allowing Geek Wave to up-sample all the way up to a 1.56M Hz sampling rate.
The DAD perk will also double the hardware buffer size between the music storage/flash memory and CPU.
Oh, BTW. We will also upgrade you from 128GB's to 256GB's of internal flash storage. Basically your Geek Wave is now the XD256!
Once again, this perk will apply to Geek Wave XD128 only, due to the board space and cost limitations.
Casey Hartwell
