m-i-c-k-e-y
And they (LHlabs) are thinking to incorporate a Wifi/Airplay module.
Sent from my Samsung Note 3 using Tapatalk Pro
New Update!
So mine is now XD + DAD + IEM + THD
New Update!
It's back.
Question to those smarter than I. Why does it cost an extra $38 for USB dac capabilities? Its something Fiio and iBasso are adding to their DAPs free of charge. Its something that I do want but wondering why it has to be paid for. Serious question. Is there hardware that is needed that justifies the extra cost because its done through firmware updates for the other two companies. Thank you.
Without USB DAC functionality, the USB connection on the Wave will do nothing other than charge the device and sync files. It doesn't have any access to the DAC portion of the player at all. So they'd have to add connections to allow data to move into the DAC to be used with a PC. Does it cost $38 for those parts and labor? Possibly.
Ic ic. So the iBasso and Fiio DAPs probably already had those "connections" in there and only had to update firmware later on. Understood. Thank you.
Put me down for the XD256+IEM+THD+DAD package
It started with a $399 device...
- add $1 for the X128 version
- add $370 for the XD128 version
- add $128 for the IEM upgrade
- add $168 for the THD upgrade
- add $258 for the DAD upgrade
- add $350 for the graphene supercapacitor upgrade
This is now a $1,322 portable music player.
This little toy should sound a lot better than the Pulse X at twice the price. The last item is not real but it is coming out next! Joke only, of course
