jcwc
- May 5, 2014
Word. I used mine ONCE. Since then, it's been a shiny paperweight on my desk. I'm back to using the (excellent) DACport.
I guess it was the volume issue that turned you off the Geek Out?
I got a couple of blast from GO 450, almost blown up my DN-2000.
I got a GO 1000, thinking it'd work with headphones and IEMs both. I most often use the latter, though, and all my headphones are currently in transit after an international move, anyway. So imagine the blast I took.
I just don't touch the volume buttons on the GO. And I am done.
Few pages back i posted this on my obervations on volume control. Hope it helps.
http://www.head-fi.org/t/711267/light-harmonic-geek-out-em-1000-impressions-thread/615#post_10562634
Reducing Master Volume from Control Panel (in my case, half) will eliminate this problem.
I still get the volume blast as well, try to be careful, occasionally forget, it can be quite uncomfortable, even with full size headphones. The other issue I haven't figured out yet is how to get my powered speakers back in use-since connecting the GO1k, no sound out of them, even when I disconnect the Geek, I can listen to YouTube, but only when I disconnect the GO and plug headphones into the PC, otherwise anything with sound from my web browser is silent. Likely some sort of settings issue, but don't know how to fix. Frustrating. I agree they had 10 products to launch and haven't tended to the initial release as I think they should have (having pre sold the later offerings takes some of the pressure off...if there was this much bad feedback about the 1st product a company produced, the next one released would have a hard time attracting more customers likely, once they read about the initial complaints. Not an issue, as Wave and Pulse are fully subscribed. Hope they will get it together, won't carry them forever, especially with other products coming along to compete.
