Interesting. I tend to listen to music at very low volume levels with isolating headphones/earphones and I still noticed the background noise with my unit (it wasn't as loud, but it was still there).
Maybe yours has higher than 3 mV noise floor.
Barely, unless I crank it...What is the point of that? I don't listen at that level ever so it is not a problem.
This is the first time i hear hiss noise from a small portable DAC. I expect GO to have at least to have the same low noise performance as other DACs.
But you're right. When the music started, it doesn't matter.
Oh you're having noise issues with the GO 450 too? I sent mine back to Light Harmonic thinking it was defective....apparently a handful of people are complaining about the high noise floor with sensitive headphones and earphones. >.>
What is defined as sensitive earphones? I also have a GO 450 but I don't hear any hiss or noise at all via my Sennheiser MX 985 earbuds (but perhaps these are not classified as sensitive).
Hi all,
Thanks for all your posts about the GO...I've tried to skim through this thread to gauge which GO would be best with the LCD 2's and just want to get a clear answer from some of you who have experience with that combo:
1. Which version of the GO are you using with your LCD 2's: 450mW, 720mW or the 1000mW? I'm curious to see if I can get away with maybe a 720mW version for instance since it's a little cheaper than the 1000..
2. These volume issues with the unit have me worried/concerned but if I'm correct, they only pertain to those using Macs right?
Thanks for your help!
Oh! Also, is there a 30 day trial period with the Geek out?? Can't seem to find that info on their site. Or what their warranty is..
I just finished demoing an iDSD but found it lacking in power with my LCD 2's..
Oh geeeez I don't know how I figured the volume issues were Mac related....wishful thinking probably since I'm a PC guy right now. Sort of hard to invest in a product that has a pretty big glaring issue, sound quality aside..
Word. I used mine ONCE. Since then, it's been a shiny paperweight on my desk. I'm back to using the (excellent) DACport.
