Light Harmonic Geek Out EM/1000 Impressions Thread
- Thread starter mikemercer
- Tags
- lhlabs-geek-out
NinjaHamster
- Nov 8, 2005
The new firmware fixes the full volume issue.
... and sounds better.
Agreed! IIRC it lowers the noise floor.
Does anyone else find the Geek 1000 to be very tubey. I'm comparing it with a fully upgraded SEX and they both sound very similar not to mention fantastic. Almost end game material.
kostaszag
- Mar 22, 2014
I know. It was my fault, had forgotten the volume on my Macmini fully turned on.
jahmed1
- May 14, 2014
Just got my Geek Out 450, which is my first DAC and I must say I'm really pleased. I immediately updated the firmware, so I didn't get the chance to test out the 3D Awesomizer though. Given how much everyone praises it, I wish I could have tried it.
There is a small question. Can I plug an electric guitar or any other MIDI device into the Geek Out and use it as an input for music recording? I didn't think about this before, but after seeing this option in the Geek Out app (as shown in screenshot below), it got me curious. If I can, what are the improvements I should expect?
Finally, I would like to ask that my compute only displaying 24 bit, 192 kHz as the highest sample rates, while the DAC is 32 bit. I've attached the screenshot of the thing I'm talking about too. Does it matter which sample rates it displays? If yes, how can I get the device specs to show up?
Thank you!
Thank you!
bhazard
- Jul 15, 2013
The Geek Out only has outputs.
You could get an interface box to plug your guitar into your PC. You could then use a program like Amplitude for amps, and then run your audio out through the Geek Out.
^Right...think you need something like a Lynx Hilo DAC & ADC.
ADC = Analog to Digital Converter. Also useful for digitizing vinyl albums to digital files (needledrops).
rlawli
- Jan 30, 2011
Thank you!
You should install and use the Light Harmonic ASIO driver instead of the built-in windows driver control panel:
First, install the LH ASIO driver. Once you have done this, a Light Harmonic icon will appear in the "Hidden Icons" popup in the lower right hand corner of your Windows tool bar.
Plug in your Geek Out, then open up the driver's "Control Panel" by clicking on it's hidden icon.
The first of the 3 tabs on the LH Control Panel, "Status" - will show "Geek Out HD Audio 1V5" in the "USB Audio" pulldown.
The "Buffer Settings" Tab can be left to its default settings or adjusted later to suit.
Open the Volume tab and press the Output button. This dialog is where you control your GO volume. It has 2 sliders, the one on the left is for the analog volume control in the GO, the right for the digital volume control. Slide one of them at least to -50dB or mute before you turn on your amp so you won't blow out your ears/earbuds/speakers. (Press the speaker icon to toggle mute.)
Open your player to its configuration/options (whatever it's called) dialog and choose Light Harmonic ASIO as the the player's output device device driver.
For example, in JRiver you go to Tools/Options/Audio/Audio Device to pick the LH driver; in Foobar 2000 you go to File/Preferences/Playback/Audio/Asio to pick the LH driver. As you can see with these two examples, you may have to poke around to find it.
Now you can queue up some music and play it at higher bit rates. Depending on your player, you may have more configuring ahead to get it to recognise and play DSD/DFF files in DSD format (look for a DSD over DoP bitstream setting).
Search this thread. Everything I've said and more is in here somewhere though not always easy to find.
chartwell85
Previously Member of the trade: LH Labs Light Harmonic
- Aug 4, 2014
We have a beta program we're running for the GO firmware upgrade for OS X
Email info@lightharmonic.com if you want to participate in this beta program.
jexby
- May 29, 2013
hit me.
sent.
hit me.
sent.
hit me.
chartwell85
- Aug 4, 2014
- Feb 23, 2011
Cool! I'd be interested in testing it too. I just sent an e-mail to that e-mail address.We have a beta program we're running for the GO firmware upgrade for OS X
I don't think there's a DFU updater for Mac yet, so this is exciting to see.
SHFT
- Sep 27, 2013
How does the Geek Out compare to the AudioQuest Dragonfly, I know the DragonFly is a lot cheaper but how does it stack against the Geek Out.
Since it is a rather powerful device has anyone experienced extra battery drain on a portable?
The GO has more power and can handle 24/192 and DSD. I own them both and I like them both but the GO is more versatile.
