- Dec 27, 2010
Thanks, @Chris Kaoss. Once upon a time I knew that, but everything seems to be slipping out of my brain...
anyone?Hello,
which HP and IEMs are good with v40 ? I listen 60% Jazz, 20% blues, 20% music with bass. .
regards,
Simon
anyone?
ok. Thank youMost IEM's sound exceptional with the LG V lineup as for headphones as long as they are not planar generally it should be able to drive them okay. I have found however that once you exceed 150ohms audio quality does start to diminish and you do need more power. It is still a phone and not a desktop amp after all.
If you are looking more for some suggestions as to what headphones or earphones to purchase I suggest you start a new thread stating your source (V40), music tastes, budget, and whether you want IEM's, Open Back headphones, or closed back headphones as well as any other details you think might be important like headphones you've had in the past, ones you liked, ones you didn't like. Open that thread and I'll be happy to help you out however this thread us primarily for discussing the phone rather than earphone and headphone buying suggestions.
Should you create that thread feel free to message me the link though so I can give you some more specific advice. You'll also get more responses that way.
Thanks
JG
Thanks for the objective comparison between the two, that was most needed.one thing feels clear at least , they both lack the ultimate base ( presence or extension or handling etc combination of those ), and they share a little edgy yet light / easy pleasurable presentation
9038s feels superior in almost any aspect ( bass drive or bass handling too just one of them ), but is also more fatiguing to listen in relax for long sessions
opinions are wanted on the subjectmost needed
Yeah.one thing feels clear at least , they both lack the ultimate base ( presence or extension or handling etc combination of those ), and they share a little edgy yet light / easy pleasurable presentation
Hello,
today I order a new V40. 399€ with postage. I cant wait for it.
Thanks to all.
regards,
Simon
