simon740
Thank youCongrats enjoy one of the best built in dac of all smartphones.
Yes, you can.Hello everyone,
the original charger from v40 is 5V - 1.8A.
Can I use power bank which is 5V - 2.1 and 5V - 1.0a
Or somethink faster like charger from Huawei P20 which is 5V - 2A, 4.5V - 5A or 5V - 4.5A
regards,
Simon
Thank you.Yes, you can.
The battery management system takes what it needs.
Make sure you're using 5V input.
Note:
The slower the better for longevity.
Yes.Hello!
me again...
when I Had wm1a I charge it to 90% and not discharge it less than 20%.
What about v40 battery? will be this ok too for V40?
thank you
regards,
Simon
I love V40.
Very good sound. Even though I currently only have the Sennheiser CX 300 II headset
Thanks to everyone for the recommendations.
regards,
Simon
yes or when it connects with an ampThe V30 enables the aux mode automatically when connected to a > 800ohm device or a non connected cable.
If you want to benefit of 2V output you've to trigger it to high gain mode.
Is this the same with V40?
regards,
Simon
An amp has higher input imp than 800ohm typically.yes or when it connects with an amp
Got no issues with android 9 on V30.Do you recomend a android 9.0 (pie)?
Or I leave it on 8.1?
regards,
Simon
I do miss the comparison with your dap in that writing.It's been almost 3 months since I got a v40 and went on Tidal Hi-Res. I've listened to the HD-600 and HEX v2 (with LG set for highest power), then mostly went with my desktop: Gumby & Rag 1. I even re-ran my seldom used DAP's for more of a contrast. I keep reading how great the Sabre chip is in the v40 - most here say it. Is it because you don't have/use desktops? Or is really a matter of being portable and not yoked to a desktop?
Because I find that in no way does the LG/Sabre/internal amp a credible match for my Gumby/Rag 1.
