I see what you're saying get a 3.5 mm headphone extension short one length of 3 in or 6 in ch and then I need to either plug in a 50 ohm headphone to it or impedance adapter pretty sure my iems 1more triple driver are not 50 ohm actually I don't know how many ohm they are maybe they could be I doubt it .
I'll get the short adapter and try that first if that doesn't trigger it I'll get the impedance adapter.
Thanks for the quick reply I think I kind of fell for the all of the awesome reviews all over the internet on these 1more triple drivers I mean they sound okay but of course I don't have enough power to power them yet so I don't want to judge them fully yet . When I pump more juice they might sound better but right now I'm finding all the reviews overhyped the bit.
Thanks again I appreciate it I'll let you know what happens.
1More Triple Drivers are 32ohms, so won't trigger High Impedance Mode (HiFi2 mode, 2Vrms). That means you're in Normal Mode (HiFi1, 1Vrms). There is a louder version of HiFi1 called Aux Mode, which is triggered when >600ohms is plugged in.
You can trigger Aux mode by plugging JUST that extension cable into the phone. THEN add your headphones.
The Imp adapter is used if you want to trigger HIM mode (HiFi2): Connect extension cable, Imp adapter and headphones in a chain, THEN plug them into the phone. Once HIM is triggered, remove the Imp adapter from the chain (you don't want to play through it). Don't take the extension cable out of the phone once you've triggered HIM, or you'll have to start over.
Make sure your extension cable is good quality, I've seen (heard) the difference when they're not.
I'm surprised the 1More Triple Drivers require this much power. I've been using 32ohm full size cans (53mm DD) as well as CCA C10 (4 BAs 1DD) and both were plenty loud in Normal mode.
Please don't take offense for me asking, but you DID enable HiFi Quad DAC, right?
On some LG models that HiFi Quad DAC settings page also shows which mode you're in. If yours doesn't, then get the $1 app "Hi-Fi Status (LG)" from Play Store.
