W1ll1eTheP1mp
I was thinking to forcing HIM with just an extender. Thats was the purpose of the HYPER 460 cable im using 64 Audio U12T which has LID system. Linear impedance Design which gives consistent reliable sound regardless off audio sourceHmm.
If i'm not all that wrong you can't trigger the HIM without adding some ohm to the sys.
Well, i'm unsure how this will affect the freq response of your preferred iem/headphone bc it depends on the resistance curve of the headphone itself.
Glad you'll find a solution that'll fit your needs.
To force aux mode i'be a really cheap 4 pol short extension cable (to make use of the micro on my CH9T) or use the Grado extension cable.
https://www.amazon.de/System-S-gewinkelt-Winkel-Stecker-Adapter-Samrtphone/dp/B00NMFKVGS
Grado Mini adaptor cable
Seems like the HYPER 460 cable has no resistente and therefore trigger HIM? Hard to know since im using Google translate from South Korean to english. =)
