Chris Kaoss
Didn't your V30s received the update to Android 9?
My V30, carrier free, is on 9 with security patch of Nov 2019.
Hmm.
The update for the V30 was rolled out on Q2 2019.
Even the V20 has received it.
Maybe they has not lauched an update for the V30s?
I don't know for sure.
There were quite a few updates from the earliest to the latest Oreo, both security, features and bug fixes. I think you definitely want to get to latest Oreo (20h), if not Pie (30b). There were some serious security vulnerabilities patched in Pie as well.Thanks for all the info. That explains why when I put that IMEI number for the 998R it confusingly shows up as a US cellular phone. It also shows up as compatible for every carrier which is really valuable so I'm keeping it for sure.
Other than security updates, I only see a few camera features added from A to H of which I don't care anything about them. I don't know how comfortable I am dealing with those ROMs
A couple questions:
1. Is it "dangerous/issue" to run on a carrier with that low of security update (4/18 in my case)? What do those "updates" really do anyway?
2. Is it the phone model or the OS (9) that allows Chrome to fill in passwords and also that addictive left swipe news feed that my V40 has?
I found this link for Bridge so I'll give it a shot soon. I've heard the same about Oreo being preferred...so I think I'll just update it to Oreo security updates version H
https://www.lg.com/us/support/help-library/lg-bridge-download-how-to-use-CT10000026-1438110404543
V60 is better than V30 in 3 ways:
1. More power. I am using 64 Audio U12 IEM, V30 sounded fine, until compared to other phones like Meizu Pro 5 (it use sabre 9018, plus dedicated amp chip. while V30 using sabre's built'in amp function). Now with V60, it is even more powerful, result in fuller more impactful sound.
2. More 'realistic'. V60 makes instruments more realistic, more believable. Compared to V60, V30's sound is more artificial, mechanical. V60 is fluid, realistic, and I tend to listen to music much longer, compared to V30. Without often pressing 'next' button to skip to next song.
3. More details. More details throughout the frequency spectrum, in a realistic way. details just flow in, instead of drawing attention.
Have you tried if changing to a different filter might affect this? I don't know if the V60 filters are the same as V30, but I could imagine the Slow filter would be a bit fatiguing after awhile.Update
After more listening, I found out V60 has sibilant issue, in the area of cymbal and snare wire (but not in the vocal area). After long time, V60 is quite fatiguing and almost unlistenable. Not sure this is the same for all V60, or just my unit, or my version (US Cellular).
Although V60's sound compared to V30 (and other sabre based dacs I have used) are more 'energetic', better bass, and feeling of more 'focused'. However the sharp focused energy in highs created sibilant issue.
I'm pretty sure it doesn't. aptX HD or LDAC are your best options. LDAC can sound pretty good, bit it's highest bitrate is best for short distances - like headphonesAny idea if LG v30+ supports TWS+? How do u go about enabling that feature. Thanks
