BlazdiqFoods
Thanks a lot! I asked because i wanted to have the lowest latency for playing fps games. Though i know cable is my best option as it has no latency.I'm pretty sure it doesn't. aptX HD or LDAC are your best options. LDAC can sound pretty good, bit it's highest bitrate is best for short distances - like headphones
You choose by selecting Connection type -> Best sound quality in BT settings under each device (which will select LDAC or aptX HD instead of lower quality codecs). Then choose bitrate under LDAC playback quality in the Developer Options menu.
Thats why i thought maybe by updating my firmware i will have the option for TWS+
