Has anyone compared this to the Xduoo X3 in terms of sound quality?
Also, if I understood correctly:
To trigger the High Impedance mode, I need the following cables:
1.
Dunu high impedance adapter (does it matter whether I buy 75-, 150 or 750 ohm adapter?)
2.
Kenable stereo jack
To trigger it, you plug the Dunu into the Kenable and then attach it to the phone, and then detach the Dunu and plug in your IEM?
To trigger the AUX mode, only
this cable is needed?
Which mode is preferable (I have the Vsonic GR07 as daily driver), the AUX mode or high impedance mode?
