eio
- Mar 19, 2009
Nice. Good see some plots.
The crosstalk on the V20 is so flat it could be software, but it looks like a common resistance on the ground return. Most likely a layout issue. Crosstalk at -70dB and below is probably not a delibarate DSP feature.
To me I would guess the amp is the improvement. DACs don't have that much intermod
thanks for help analyzing! you are right this crosstalk doesn't make sense as a DSP feature.
it was tested with no load (lineout), i'll test with low/high resistance dummy load later.
