Chikolad
- May 31, 2008
Poweramp preamp level in EQ is set to zero dB? EQ is flat?
Everything is reset to default.
From reading the poweramp forum max isn't currently working on supporting the hi-res output for the v20 atm, and is focused on releasing the next iteration of poweramp(January 2017), then would work on the hi-res request list.
I tried out poweramp alpha 704 and I always get the failed to hi-res output as well. I saw only one other person that had the same issue.
Anyone have a link to download the 704 apk that the hi-res output works for the v20?
In the poweramp / settings / audio / output
Whenever i try to use the hi-res output with my headphones (ath-a900x) it will say failed: poweramp hi-res exp output.
It will then proceed to default to the opensl es output instead and the files will then be 16bit - 48kHz
I dont have output on mine?
its because powramp alpha 704 does see snapdragon only and not the hifi dac
im on beta version not alpha?
wait so Poweramp on the v20 doesnt play high res music?
