FSTOP
- Jan 10, 2010
I'm a Note7 refugee, looking for my next replacement.
Had actually considered the V20 (when it was first talked about but not released) before i got the n7, but have been very happy with Notes, as i DO use their main feature, the stylus, often (have an art degree, and the Note is great for drawing). I also build my own speaker systems and use it to sketch out ideas while trying to engineer a new design.
I've no doubt that the audio on the v20 is clearly better than Notes, or any other phone out there to date, but wondering how other Note refugees are adapting to LG implementation, etc. Also a bit worried about the screen color balance issues, as my day-job is a photographer, and want to be able to transmit photos that are fairly accurate from the field if need be...
But, audio-wise, i was liking the N7 with PowerAmp Alpha (with Experimental Hi-Res output that is). I also have over a dozen custom EQs for various HPs, IEMs, and Speaker systems, which i hope to export. Any problems with using PowerAmp (pro or Alpha build) on the V20? I've been a PA user for years, and a beta-tester--just really think its the best player i've found for my tastes/SQ. So the QuadDAC is still usable with a non-stock player? From reading the thread, not sure about the DAC implementation--is is at all user-switchable (on/off) or only automatic with the 3.5mm plug-in?
Also, any mSD card issues (brand/size)? i'm hoping to transfer my Samsung 256gb card (already loaded with 20K songs) to the new phone.
I think other than the stylus, the main feature i'll miss is wireless charging. With a removable battery (the main feature i wished the N7 had) i could foresee wireless charging implemented later (yes, the stock back is metal, but a new QI back could be plastic) either by LG or third-party. I've reverted to my Note3 for the time (and am on my second week of waiting for the shipping box from Verizon to return my N7!) and have used a qi coil strip inside the battery compartment easily for years now. Are there any pins for the battery connection inside the LG?
Anyway, THANKS for any help/advice out there--think i just need a very tiny push to hit the order button after my recent misfortunes with the N7!
![frown.gif](http://files.head-fi.org/images/smilies/frown.gif)
![wink_face.gif](http://files.head-fi.org/images/smilies/wink_face.gif)
