LG V20 Sound Quality
Discussion in 'Portable Source Gear' started by zachchen1996, Aug 1, 2016.
239 240 241 242 243 244 245 246 247 248
250 251 252 253 254 255 256 257 258 259
  1. m-i-c-k-e-y
    There is also Q8 w/c is available.
    Edit: Not V20s equivalent but has ESS DAC.
  2. Emulle
    The difference is that V20 have a 5.7" display vs 5.2" on Q8, removable battery on V20 and waterproofness on Q8.
    Also, no root available as of yet for the Q8 (So no 16bit 44.1kHz support through stock player).
    m-i-c-k-e-y likes this.
  3. totte
    A polish coworker bought a korean import in Poland and brought it to work in Norway to give to me.
  4. kkl10
    I think I'll wait a few months to see G7 prices fall down a little more. I've read that all G7 versions feature the quad dac... Not sure how accurate that is. Otherwise, I might stick to a dedicated dap.
  5. davrt
    Quick question for everyone with Oreo. When the Hifi DAC setting is off, do you get small volume steps or the same large volume steps from Nougat when changing volume? Media volume, not ring tone volume.
    When it's off, I get the large steps. Wondering if anyone knows how to fix it to also get the small steps. It's been kinda bugging me. I just want consistency.
  6. sebiambrus
    mate can you please explain me how to circuit this Android Upsampling bull sh it since it ****s my deezer experience and UAPP not systemwide
  7. stuck limo
    Does anyone have any Pelican-like cases to hold their V20 + earbuds in it? If so, please link us so anyone else interested (besides me) can buy them.
  8. 329161
    My v20 hasn't received the Oreo update yet, but it seems to now be able to do AAC Bluetooth. Has anyone else noticed this?
  9. howdy
    Mine finally got the update Friday. I didn't think out it was ever going to happen, he'll the next update 9.0 pie is coming out soon.
  10. andrewwardell
    Based on LG's previous track record It'll be out just in time for the next presidential election!
    HolyBiscuits, ljnew and howdy like this.
  11. Naschy
    Hey guys, I'd appreciate some help if someone could be so kind. I tried searching but I'm getting conflicting info.
    I have a unrooted H990DS variant (so no Oreo for now). I want to get the best audio fidelity I can out of the phone. I primarily use two headphones: Xiaomi Hybrids and Philips Fidelio X2s. They both fall below the high impedance threshold (32 and 40 respectively) so only trigger Normal Mode.
    Now, and again I get conflicting info when searching, does Normal Mode engage the quad dac? Some say it does, some say it only enables one of the dacs.
    I've found a method for forcing it into External Device mode. For the Xiaomi's, plug the cable in holding the play button on the inline remote. Hold it and the Mode changes to External after a few seconds. For the X2's, using a Vmoda mic cable, have the volume slider all the way down and plug it in. When you slide it back up it goes into External Mode.
    I understand External is the middle ground between Normal and High mode, and has high gain than the base mode. My question is, with External Mode, do you still get the Quad dac and only lose some gain as compared to High Impedance?
    Lastly, I've read there's a glitch deciding higher quality music files on anything below Oreo. Do I need Neutron MP to rectify this?
    Thanks in advance if anyone can help.
  12. Emulle
    Hey,
    Let me just start by saying that the "Quad DAC" is enabled and in use in both normal, external and high impedance. It is only the gain & output vrms that differs between these modes. Why some people like to argue that external or high sounds better is that louder volume is often perceived as better sounding.
    Would you mind linking me to the high fidelity glitch statement?
  13. LightBlue77
    There is a simple solution: buy UAPP.
    On the other hand, i have H990N model and it always goes in hifi mode when i plug a headphone or other 3.5mm cable of a loudspeaker amplifier for example. it is actually called "hi-fi quad dac" mode. i cannot activate it if there is nothing plugged in but i can deactivate it while i use headphones. in this case i noticed the volume goes down, i didn't care to check if there is any quality degradation, it seemed the same just at lower volume.
    About activation of hifi mode, i don't know if it's configurable by user. it might be in android config files, maybe someone would help you. there is only a menu activated on hifi mode allowing me to independently control the volume on left and right channels and that's it. No other trigger, setting involving impedance or anything else. At list not visually noticeable.
    Now, UAPP related, i already mentioned there is a clear difference between sound quality using tidal own app and tidal via uapp, uapp is way better. i don't know if the same applies while listening your own files using stock lg player, it is possible stock lg app is good enough. But because lately i only use tidal via uapp and this app is recognized as one of, if not the, best, i stopped worrying about what lg does behind as uapp directly accesses internal hifi quad dac.
  14. Naschy
    Thanks for the info. That's good to know. I think confusion stems from this: 'The Quad DAC’s low power mode shuts down three of the four DACs when they’re not needed, to increase battery life when playing lower quality audio or using lower quality headsets. – Ken Hong, global communications director for LG'
    As for the last issue, I'm referring to the downsampling/resampling thing. I'm trying to find a succinct writeup but that's eluding me. Someone discusses it here: https://forum.xda-developers.com/showpost.php?p=74098912&postcount=3
    Thanks for the help. I'll look into that app. I have credits to burn on Google Playstore from all those survey questions.
  15. Emulle
    Well I can certainly understand the confusion going by that statement.
    Oh, now I understand which 'glitch' you mean, in short anything above & including 24/48 to 24/192 will playback bit-perfect (flac & dependant on player).
    The problem is 16bit music, which will be re-sampled to 24bit, depending on the player (solvable by rooting & editing build.prop with audio.offload.pcm.16bit.enable=true).
