Sound Eq
- Nov 9, 2013
Wat casing you are using for this V20?
Currently using this, same as my previous ip6 version:
be very careful cases with top flaps that have credit card pockets will leave permanent lines on the screen that wont get out, so you have been warned. They will appear under lights when the screen is tilted
those lines appear when the screen gets a bit filled with finger prints, when u clean the sreen the lines will appear if they went away, but once your finger smudges that screen again those lines will come back at the exact location where the credit linings are
honestly i am wondering what type of glass is the lg v20 made of, or if there is a coating on it that leaves such permanent lines
this has been mentioned on xda as well and i have that problem myself
