Hi,
I have a pair of Dan Clark Ether C that I absolutely love. I saved up along time to afford them. They have been my daily driver headphones, I have been using them for 4 years now.
A few months ago I noticed the volume on the left speaker started fading down and staying a touch lower then the right speaker at random times. The headphones can work fine for a whole day, then the next it happens all the time. The problem has become frequent over time, happening every time I use them now.
It usually goes away when I unplug them and wait a few seconds before plugging them back in. I thought it might be my amp, but switching to a different one or a completely different source device it still happens.
I then thought it could be the cable, so I tried different ones, and it still happened. I can even swap the left and right connector on the headset and the problem stays on the left speaker.
I reached out to Dan Clark audio, and they can't help me since the headphones are too old(They are the one off FIFA edition).
I am good at repairing electronics and want to try to repair them myself, since else they are just a 1000$ paper weight.
I would think that there is a wire problem inside with the connector or the speaker.
My question now is if anyone here has experience opening the carbon fiber cup on the Ether C headphones?
I have tried opening them and they seem to be glued on.
I've tried loosening the glue with a hot air soldering gun, set to a safe temperature without any luck.
Dan Clark support told me they can't be opened without destroying them, but I want to try my luck anyway, since they are already broken.
Any help or tips are welcome.
Thanks in advance.
Thanks in advance.
