Tung Sol 5998 is more powerful and more vibrant. It's like an energised 6080. Bass is pretty solid. That said I find the Mullard 6080 having a very good sweet, warm tone. It's very clear too. The other extreme of the RCA 6as7g.
IMO the TS 5998 is definitely better than Mullard 6080 and the opinion of many others too, otherwise the price won't be creeping up so high. I have a spare pair but I need to test to see if it plays well. If it is, I'll sell it to you Bruce. One tube of the spare pair was bought NOS from Langrex.
Thé tube test machine has an accompanying chart where each tube type has a minimum reading that is considered end of life, and a maximum reading considered as New. When the tester gives you those reading numbers, he should give you the low and new values in order for you to make sense. Otherwise ask for those.
imho, the $250 ok gec 6as7g still has a better value than the $300+ strong nos chatham 6as7g pair in the earlier discussion.
In the 6AS7G thread, I started to understand more about the values.
xx%
-- some testers do output the percentage
gm = ????
-- other tests report the gm directly.
-- Usually the Gm value of the nos is larger than the nominal value on paper. e.g., 5693 is 1650, 5998 is 15000, 6AS7g is 7000 etc.
-- There is a minimum value. Maybe around 50-60% of the book value.
Ia
-- I can be wrong about this, but I think many others report this value without the units. For example, 76/66, minimum 36/36.
These three do not need to be proportional because they are tested in different ways.
For example, you can have 60% in the #1 test, but the gm percentage is maybe 58%, and your Ia is different.
