UntilThen
- Jun 16, 2015
Tonight's listening session.
Do you still own the LF339? The last couple of days, I've been singing the praise of Elekit 8200 but the LF339i is right up there in it's own way. I just can't get enough of Figaro lovely warmth, bass weight and sparkly top end.
A friend who is not familiar with tube amps but very familiar with high end ss amps, came over and when he had listened to the He1000se out of LF399i, he wanted to buy my unit straight away.
I will not sell this new LF339i in black. It will stay with me forever, no matter what other tube amps I get. That's how much I love the tone and the looks.
Another thing most people probably don't realize is that you can run 6336 tubes in this amp (it's able to dissipate the heat according to @xmdkq). Here's a picture of him doing it while building my amp a few years ago:
I would caution against this as I wouldn't want to see others amps die on them. I have these tubes but have decided to not use them as I would not want to shorten the life of my amp and there are plenty of other tubes to use. Plus those 6336 tubes are on fire when they are used. You could cook food real fast on them.
From @tintinsnowydog:
These draw 5 amps of current vs. the 2.5 amps of 6AS7 equivalents. It runs ok but is taxing on the transformer. Using it for too long could shorten the lifespan of the transformers and components. You can use it for short periods of time, just watch for overheating by touching the left and right black plastic covers.
From @xmdkq:
I have tested that I can work for a few hours and observe the temperature of the power transformer.
Is there LF339i (new version) with 6j5 / l63 inlet tubes?
The elekit amps have always been on my radar as I like doing kits. Previously I've done the bottlehead crack and the transcendent sound masterpiece amps.
Wondering why headphone out cannot be used as a preamp? I did an experiment tonight at the cost of a headphone
Sorry, slightly confused.
So you had a hifiman headphone plugged into the 339i preamp rca (via an adapter) and it blew the drivers?
dac -> 339i -> speaker amp -> he6
You blew your Hifiman HE6? Ouch....
Isn't the LF339i pre-amp a variable out? Surprised it would have blown it with volume on 0 and no music playing.
I got a huge scare last time when I thought I blew my HD800S when I heard popping sounds with it connected to the LF339 while powering up.
What is the amp?Oh, yeah. that's a missing piece.
I power the HE6 by the speaker amp through speaker tap. So it was
I was trying to see the diff between 339i's headphone out and preamp out.
In the past I know the headphone out in a stereo preamp is not that powerful. So I thought I could give it a try. I was WRONG!
What is the amp?
If volume of the 339 was at zero, there cannot possibly sound coming out of the outputs.
Power amps are know to have loud pop noise on startup, can be DC voltage. Especially vintage amps with in need of service capacitors. And that kills headphones for sure.
