Very cool! Battery bias it is then, keeps an electrolytic out of the signal path, should improve the sound. Most people do not realize it, but the last cap in the power supply is in the signal path in these single-ended amplifiers, so the BHC caps in this case. Another method to remove the cathode bypass cap, other than fixed bias is to use an active load, again like a CCS. The effect on the internal resistance leaving the cathode degenerated is minimized in this case, so you can get away with leaving it unbypassed. Can also take the signal output from the source of the bottom CCS FET, making the effect on the internal resistance irrelevant, although this technically puts a transistor "in the signal path", but for those that are not afraid of a little sand assistance, this can be very beneficial to the circuit
especially if you have a difficult-to-drive output tube, like a 300B.
