Holy crap...
Okay first things first, got the transformers in the amp. Below is the secondary wiring, 470ohm resistor across the output to protect the transformer from open circuits.
Had a few other things to finish up, nothing major. Here is the final ciruict.
After I finished wiring, I eyeballed the whole circuit, reflowed a few solder joints, then brought the circuit up on a variac and checked voltages. Here is what I got for the two channels using the GEC U18/20:
MH4 cathode: 2.44V / 2.47V
MH4 plate to cathode: 174.4V / 184.4V
B+ top of OPT: 312V / 312V
6A5G cathode: 44.6V / 45.5V
6A5G Plate to cathode: 247.6V / 251.5V
All of these values are within 1-2% of my targets, I was absoltuely dumbfounded that I nailed them so accurately. That crazy Georg Ohm knew a thing or two. Difference between the MH4 plate voltages is tube variation I am sure.
Well then there was only one more thing to do...have a listen? NO! Take measurements of course. Here is the frequency response, down ~2dB at 20kHz, might investigate that, but essentially flat from 20Hz - 20kHz
I am witholding FFT measurements until the amp settles down and have some time to mess around with different tube combinations. Here are some beauty shots of the final product:
So how does it sound...with all of the bias suppression I can muster, it sounds incredible. I braced myself for bad sound (expect the worst, hope for the best kind of thing), but it didn't come. The soundstage is absolutely expansive, the bass is deep, full, and tight, treble is detailed, airy, and not the least bit strident. Maybe I shouldn't be, but I am still a bit shocked it all worked out! It is a keeper.
I have been listening for about an hour straight, the panel with some of the dropping resistors on it does get warm, but so far I think it is manageable, haven't taken any surface temperature measurements yet. Will be adding some ventilation in the near future.
I guess that is all for now, just going to keep on listening
have quite a few different 4V drivers to try out (REN904, MH4, E424N, A4110, NR52, K1694), a few different rectifiers to try, and different makes of the 6A5G, but probably won't get to it tonight, might try one other combination. At some point I have to get this baby in my stereo, that will be its final destination, but enjoying headphone listening for now.
So overall a rousing success I would say. I will have more impressions and measurements to come I am sure (need to get a square wave generator...).
Big thank yous to
@Tjj226 Angel ,
@2359glenn , and
@A2029 for the input along the way. This is the hardest DIY project I have ever taken on, learned an absolute ton in the process. I'd imagine the first one is the hardest, should be smoother sailing from now on.
