- Oct 14, 2013
Coax via rca never give me such error, maybe your cables or source ?
what's "MU"?I don’t think there has ever been actual driver from MU, only Amanero
cable is good because I used it on my rig from sound card. Instead to plugging into this dac i had it plugged into other protable dac and it worked. when i switched to usb input, everything works just fine. i guess i could try aes, but I just wanted to try direct coax from soundcard to bypass usb completelyCoax via rca never give me such error, maybe your cables or source ?
what's "MU"?
Dont understand. If your usb output is working, then your driver is working. I assume you are on windows or you dont need drivers anyway. Where are you outputting coax from. Onboard audio from pc? Then you should install motherboard audio drivers.Gents, what is the date of the latest Amanero firmware? Also, there is a March 2018 firmware release here: https://download.shenzhenaudio.com/LKS/
Dont quite understand. If your usb is working
Also, on the D004 product page there is a link that just says "Driver:http://www.mu-sound.com/about.asp?id=3" What is that a driver for? (mu-sound seems to be down now.)
Should I update the firmware and driver, and if so, how do I do it?
Depends if you are oversampling pcm to higher pcm or dsd. 9038pro in 004 can do both. For pcm, as high as 384k. For pcm to dsd upsampling, as high as 8x which is 512dsd or 22.8m. In jrive, go to setting and dsp & output format.Has anyone had a chance to look into what the ES9038Pro does when it takes in PCM ? I am talking about Oversampling processing from the 9038Pro, what rate is it doing at 2x or 4x or 8x or 16x ?
Yeah, this part I do realize, but I wonder if using pcm 384khz, does es9038Pro process it by going 8X ? Lks004 is basically capable of DSD 1024 by i2s ....I do not know what source out there can do this yetDepends if you are oversampling pcm to higher pcm or dsd. 9038pro in 004 can do both. For pcm, as high as 384k. For pcm to dsd upsampling, as high as 8x which is 512dsd or 22.8m. In jrive, go to setting and dsp & output format.
No. You need drivers for your onboard audio. It should be on your motherboards download. Lets say its Realtek HD-audio. Download the install files and run it. It should become available as an output sound device you can select in your player software.I wanted to summarize so I dont go crazy.
If you're running via USB, then you need the drivers. If you are running coax or opt directly from on board sound (back of PC), then you need nothing buy cable and it should work? Or, I am missing something? I tried everything (coax and optical) but I still get that error: Unrecoverable playback error: Could not initialize the driver
No. You need drivers for your onboard au.dio. It should be on your motherboards download. Lets say its Realtek HD-audio. Download the install files and run it. It should become available as an output sound device you can select in your player software.
Is coax output available under wasapi or kernal streaming?i do have them installed because before this dac, I had ifi micro idsd dac and connected from back of pc rca (coax) to micro idsd rca coax and all worked. so i simply removed micro idsd and connected into new dac and that error. unless I am missing something>? i def get the output device but when I chose it, speakers play, vs before same output device went to headphones. the error is for the chosing asio output, not the direct realtek hd digital out
not that I know. that's the weird thing...why would diff dac play speakers vs headphones. i may need to unplug speakers and see if that helpsIs coax output available under wasapi or kernal streaming?
Try installing asio4all and see if the coax nebcomes available as well.not that I know. that's the weird thing...why would diff dac play speakers vs headphones. i may need to unplug speakers and see if that helps
