ptolemy2k6
- Mar 11, 2014
quick q everyone: if one don't have dsd files, then is there any benefit is using i2s vs bnc or optical or coax?
i thought the main reason to use i2s is because of native decryption of dsd stream.. my thought was that if i dont have many/any dsd files, i can run a normal/longer cable to it . which is the preference these days? coax (rca), aes (xlr), bnc (coax connector)?Well, DSD Native suck on LKs004, especially if you try to run it at high quality PLL.
The I2S on the LKS004 Sound very good, eventhough I am still running PCM which is also upsample to 192khz
There is never Native DSD by I2S or Coax, these are Multi-bit, and Native DSD is Single 1-bit. Every DSD will be dissected into 2 or 3 or 4 bits of DOP, which is essentially PCM. So DOP is never Native DSD.
The differences is that real PCM will be upsample and worked on by DAC, the Multi-bit DOP will be realized by the DAC and then bypass toward the final step of Capacitor arrays to analog signals.
The only Native DSD is Direct DSD Digital toward a capacitors Array (low pass filters) and no DAC in the chain . Because Native DSD is an already processed signals into 1 bit. Whatever you are using in between is never Native DSD
I would go with Coax, but usb isn’t bad on lks004...just DSD is a problem, and that is caused by Amaneroi appreciate the explanation . given such then, what would be your preference, if i2s is not possible.
thank you
If you are using the USB port, I would think so, or you can stick to low DPLLso i have dsd files mostly. will it be better i use foobar to convert to pcm first when playing?
....a few posts ago on this thread somewhere you told me that there is nothing wrong with the Amanero board?
POST: 675
OK mate, cheers!That was when both of us speaking about the powersupply and the Brass Pins Interconnect of the Amanero stacks. About the Amanero as ddc conversion module ? It is bad with Native DSD at high speed processing. It doesn’t matter anyways because you can still stick to low DPLL like BW16 ? Because it Bypass the ESS9038pro anyways. It is just annoying when you are back to listening to pcm, you need to readjust the Bw
I don’t think there has ever been actual driver from MU, only Amanero
