P
There is a thread on github on this Just google lks mh-da004 github. The latest version is be2004 from memory, out a few weeks ago. Im on Windows so I havent come across the issue myself. But apparently on some linux music server, there are hissing background noises when playing dsd. If you dont have the problem, its up to you if you want to try that latest version to see if you can hear any diffrences.I'm using USB in. It works, but if LKS sees fit to release a firmware update I believe they did it for a reason and I should probably update the firmware. Same for the Amanero USB. Often, these releases are not just bug fixes, but new or improved features or improved sound quality.
I'm running a Windows 10 Roon server to a Sonore ultraRendu or to a SOtM 200 ultra trifecta. Both are Linux, I believe.
Thanks for your help!
