Markup of some of the common mods
Initial set of modifications:
[1] XO Crystek CCHD950X Qty: 1
[2] Schottky High Barrier diodes, fully insulated low leakage, Vishay MBRF10H100 Qty:28
The actual diodes are black in the top right of the picture on the Amanero PSU
[3] Tantalum Vcom bypass Qty:2
Generic Yellow bead solid tantalum 100uF 10V eg AVX
TAP107K010SRW
Unit in photo is a Wet Tantalum 150uF 10V Vishay 109D157X9010C2 (Expensive)
Followup modification set:
[4] Analog post filter.
(Check your actual DAC post filter configuration is similar to my early revision 004)
33nF 63V 5mm lead spacing 1% Kemet PHE426 metallized polypropylene Qty:4
2200pF 100V 5mm lead spacing 1% Vishay KP1830 film/foil Qty:12
[5] Wima 0.15uF 100V 5mm lead spacing metallized polypropylene Qty:14
[6] Texas Components Vishay 0.1% TX2575 2W Z-Foil resistors for I/V Qty:4
Not shown in picture, on underside of board, refer to earlier posts
https://www.head-fi.org/threads/l-k...van-dammes-double-impact.840938/post-16019754
[7] Big Mundorf 10000uF 63V. Qty:2
Replace little Mundorf LKS is using in later revisions of the LKS004.
