b0bb
- Oct 15, 2014
Add resistors, diodes and caps
![B61EA09C-DE69-4E0F-ABB3-D576A1F6D4B1_1_105_c.jpeg B61EA09C-DE69-4E0F-ABB3-D576A1F6D4B1_1_105_c.jpeg](https://cdn.head-fi.org/a/11387912.jpeg)
This is the DS26LV32A I2S receiver on my DAC.
It is not LVDS, instead it runs RS-422, a slightly different protocol.
RS-422 signal levels are higher than LVDS, this might explain the slightly weird termination that LKS used to make it compatible with LVDS transmitters.
The problem I have with this chip is that it is being operated beyond its limits. It is specified to run up to 32MHz.
DSD512 is just under 50MHz, as such I2S performance is suboptimal on the 004
I replaced this a faster receiver from Sipex/MaxLinear, the SP26LV432CN is designed to operate up to 50MHz
There was an immediate improvement, like a haze was just lifted from the music, everything become clearer.
Soundstage became wider, high notes lost the vestiges of sibilance,especially percussion instruments.
Bass notes went lower without getting muddy.
I can now reliably drop the DPLL setting down to 7 with DSD512, it was not stable with the original receiver chip.
Power consumption dropped between 6-10% with this new receiver chip.
Always interesting to see other people's setups.I thought it might be interesting for you to see my setup.
The big screen turned out to be an advantage in retrospect, because I can reflect the sound downwards.Always interesting to see other people's setups.
I considered a big screen but decided I didn't want anything like a TV in my listening room and settled for my Android tablet as controller.
Hope you've put a choke on the TV power cable because of nasty SMPS noise back into the power circuit.
Thanks and happy christmasI knew you would do that.
Great job!!! Your allways faster than me. I actually had the same idea. And now I know, it's a good one.
Marry Christmas to everyone
Did you get a reduction in buzzing noise from the transformers when you used a 2-phase power feed?Mains filter in the basement.
left: Subwoofer isolation transformer 2500W with screen shielding between primary and secondary side
center : Accuphase integrated amplifier isolation transformer 2500W with screen shielding between primary and secondary side.
right : DAC and 9V Power Supply primary isolation transformer 1500W with screen shielding between primary and secondary side.
All transformers are operated with 400V two-phase current. this halves the interference on the power grid, and the phase is shifted 30 degrees forwards, where there is less interference from rectifiers.
