Yes, at least 70% reduction in mechanical noise.Did you get a reduction in buzzing noise from the transformers when you used a 2-phase power feed?
L.K.S. Audio MH-DA004 Dual ES9038PRO DAC - Van Damme's double impact?
- Thread starter PitBul34
What a beautiful system. And a wonderful listening room. I love such wooden floors. Great taste!Don't have a lot of Watts, but the best watt is the first watt .. my home-made flea watt amps
and old speakers .. Merry Xmas !!!
Did you really build the amplifier yourself? And yes, it's true, the first Watt is the most important and the most critical.
Even though I have at least 280W's, I almost never reach more than 1W.
How is the deep bass with your tannoy's?
Thanks Xoverman.
I like your v-shaped high ceiling, it adds natural reverberation to the sound.
Yes, I built six Direct-Heat-Triode monoblocks, starting from wood planks, metal plates,
drill a lot of holes, solder a lot of joints. There are no capacitors along the signal path.
The Tannoys can go ~35Hz ... shake the floor with 0.5 watt when I play Cavelleria Rusticana
Dances with Wolves...
I decouple the speakers from the floor using tiles and little screws, really help the bass.
Xoverman, I have to thank you again for your "copper wall" modification.
It yields great improvement.
I *think* you have Accusilicon clock in your LKS ?
What do you think of it ?
Bateman's capasitors comparison:
https://www.google.com/url?q=http:/...FjAKegQICBAB&usg=AOvVaw1QPTrEZlSwG08jXVSDGi7m
Yes, I have the impression the Accusilicon brings more focused imaging and better controlled bass.Thanks Xoverman.
b0bb
- Oct 15, 2014
Did you buy it from a place other than Audiophonics or Magna ?Yes, I have the impression the Accusilicon brings more focused imaging and better controlled bass.
Pulsar is not going to last forever so I am looking for viable alternatives.
AS318B does not seem to be on sale anymore
I currently evaluating SiTime SIT-5157 and Bliley BOVTL
SIT-5157 is a MEMS TCXO, surprisingly good expecially very deep hard hitting bass.
SiTime has increased prices, this used to sell for 30USD, it is over 50USD at the distributors today.
I am planning to get SIT-5357 which is the low phase noise variant.
BOVTL is a low cost OCXO, Bliley just starting selling to endusers, they specialize in OCXOs.
This OCXO as a proof of concept to see if it will work in the LKS, I probably order one of their higher end units with low phase noise
BOVTL rms jitter in the 10Hz-10KHz range is 160fs, CCHD950 is 226fs, AS318B is 200fs
Picture of the SIT-5157 mounted on a Twisted Pear Rhea adaptor.
@fmzip, this is what Rhea looks like
![0545FF95-2056-44CB-9CCB-F6554D8C4CAB_1_201_a.jpeg 0545FF95-2056-44CB-9CCB-F6554D8C4CAB_1_201_a.jpeg](https://cdn.head-fi.org/a/11389235.jpeg)
![588339A3-D1DB-41CD-8989-B6D0A931369A_1_105_c.jpeg 588339A3-D1DB-41CD-8989-B6D0A931369A_1_105_c.jpeg](https://cdn.head-fi.org/a/11389251.jpeg)
ti5002000
- Jun 20, 2012
AS318B does not to be on sale anymore
I currently evaluating SiTime SI5157 and Bliley BOVTL
SI5157 is a MEMS TCXO, surprisingly good expecially very deep hard hitting bass.
I am planning to get Si5137 which is the low phase noise variant
BOVTL rms jitter in the 10Hz-10KHz range is 162fs, CCHD950 is 226fs
Picture of the 5157 mounted on a Twisted Pear Rhea adaptor.
I have been using the Sitime 5357 for a long time now. It is my favourite with the DAC. Never looked back.
Great definition in all the aspects of the music. It may not have the low phase of the crystek and the accusilicon but I didn't miss it one bit. It, however, has great frequency stability under temperature and vibration which can explain the good performance.
I liked the bass of the accusilicon but didn't like the treble. In my opinion, a bit too plastic.
b0bb
- Oct 15, 2014
SIT-5357 rms jitter is not too far off from the CCHD950I have been using the Sitime 5357 for a long time now. It is my favourite with the DAC. Never looked back.
MEMS XOs are more resistant to vibration, if you have the DAC between 2 large speakers
it will perform better than the conventional quartz crystal.
![phase_noise.png phase_noise.png](https://cdn.head-fi.org/a/11389262.png)
fmzip
- Jul 7, 2010
Markup of some of the common mods
[3] Tantalum Vcom bypass Qty:2
Generic Yellow bead solid tantalum 100uF 10V eg AVX TAP107K010SRW
Unit in photo is a Wet Tantalum 150uF 10V Vishay 109D157X9010C2 (Expensive)
b0bb,
Is the polarity marked on the board for installation on the tantalums? If not, is there a marking on the OEM caps that are there?
Thanks for the shot of the Rhea board, I have one on the way
fmzip
- Jul 7, 2010
My documentation starts on page 171 of this thread, but it's all for the latest generation.
It's too bad that LKS stopped using a high current regulator for the clock. I would have liked to use an OCXO, but found that the Accusilicon was absolutely excellent.
I wonder why they put silver mica in the I/V conversation stage ?
Guys,
Where exactly did you solder the .1 uf cap when using the Accusilicon clock? Is it underneath the clock or on the bottom side of the PCB, between pin 7 & 14? Ready to start surgery tomorrow, creating some work instructions for the shop floor.
http://www.accusilicon.com/docs/AS318BM.pdf
b0bb
- Oct 15, 2014
It is marked on my board, remove the original cap to see if it is there on yours.b0bb,
The tantalum cap will have a marking for polarity, post pictures if unsure.
Match up the polarity on both the board and cap, do not power on until you have performed this check.
Tantalums are not tolerant of reverse polarity voltage.
b0bb
- Oct 15, 2014
Guys,
Where exactly did you solder the .1 uf cap when using the Accusilicon clock? Is it underneath the clock or on the bottom side of the PCB, between pin 1 & 14? Ready to start surgery tomorrow, creating some work instructions for the shop floor.
Where did you buy AS318 ?
fmzip
- Jul 7, 2010
I bought the last one they had at Magna.
Thanks for the explanation on the tantalum cap polarity. What type of cap is the tantalum cap replacing? I was wondering if there would be a polarity marking under the black covering of the cap if it's not on the board.
b0bb
- Oct 15, 2014
Aluminum electrolytic
AuxInput
- Oct 4, 2011
hey guys, I soldered the 0.01uf film cap across the +/- power pins of the clock on the under-side of the board. The Accusilicon clock is a large format 4-pin clock that inserts directly into the holes on the LKS board. I ordered mine from Audophonics in UK when they had them. They still have Accusilicon clocks, but not the 100 mHz requried for LKS. I'll post pic here again:
![IV_back_muse.JPG IV_back_muse.JPG](https://cdn.head-fi.org/a/11391429.jpg)
