Lennym
I don't think the Coherent cables remove anything. I think my other cables added some hardness.
These passive components added something? I don't think so.
Cables are complex transmission lines. They can add nonlinear distortions.These passive components added something? I don't think so.
It sounds so real that it scares me.
After listening to tons of music I then tryed diferent settings. But 192KHz and sinc-m is the only setting that gives this effect.
I hope someone can explane what is happening here.
I tried different filters and also higher frequencys, but only 192KHz and sinc-m had the magic with my lks 004.HQPlayer is the gold standard for upsampling, it just sounds better than the others, and I am still running HQP 3.xx, I have not upgraded to 4.xx. For perhaps a year I used Poly-Sinc-XTR-mp-2s as my main filter it was so organic so real. Then this year I started playing with others. I liked Poly-Sinc-ext2, then I went to Closed-Form-16M and enjoyed that for a while then I tried sinc-M, OMG now we are talking it was XTR-MP-2s but more organic and full, more transparent more dynamic. I fell hard for it. Sinc-M is a linear Phase filter, with a very sharp cutoff and high degree of attenuation. It also has 1 million taps and requires a very powerful CPU and a GPU for cuda offload at least at DSD512. Now I ask why are you only running up to 192K PCM, it is DSD512 where the magic happens try that and you will never go back.
Really with this dac the goal should be DSD512, it sounds so much better, why mess with the other stuff. (BTW, my CPU and GPU cannot do the non-2s XTR-MP filters they are to intensive for my rig so I have not heard what some say are the best sounding of all.)
What other dacs have you compared the lks to. D70 is less than half the price of the lks004. I know price is not everything. But on the other hand, there is also a saying that you get what you pay for.Interesting to read some comments here about bass from the LKS. Mine produces extraordinary, potent and very extended bass down into infra-bass air movements. It's the best DAC I've ever heard for bass.
I had a Topping D70 on my system a couple of weeks ago. Not bad, verging on good in the midrange, but the bass was lightweight in comparison and the dynamics a little bit restrained.
That was also my first impression, but then I listened more closely.Yes. HQP+192K+sinc-M --> LKS004 is spacious.. instruments (like trumpets) more pronounce.. vocal image well defined.
BUT minus bass (b0bb also points this out earlier), bass cello disappeared in Vivaldi's summer concerto !!
