Lennym
I can confirm the relatively high output impedance of the LKS phono and balanced outputs. I first tried the phonos driving my power amp directly, using excellent Black Cat Airwave 3202 interconnects and variable output volume. Very poor, limp and with a tilt towards the treble. It simply cannot drive a power amp well. I switched to using the XLR outputs into my Pass preamp and that was much better with the power and slam returning. Even so, I rejected first Townshend DCT-300 XLR interconnects as having some glare, followed by Townshend Fractal F1 XLRs which sounded better but still had a hot treble. I also tried Yannis ConnectLitz XLRs and they just sounded different. Finally, when I tried Coherent 6D XLR interconnects, the results where what I wanted - a balanced and powerful sound with very extended bass and phenomenal midrange clarity without glare.
This to me proves that the LKS doesn't have inherent glare, but it does have an output stage more susceptible to cable performance than many other DACs.
Cables are extremely system sensitive. Apparently you may have found a cable that rolls the highs in a manner that's pleasing.
I have not found the LKS to have a disconcerting treble at all, at least not when it's running at its best. By that I mean that its performance to be at its very finest seems to depend upon the quality of the electric current. When it's at its best I just want to listen more; when it's not my sessions are shorter. I live in an urban area and I don't have a very sophisticated power set-up. My listening experience is live un-amplified concerts and vinyl with a 3 stage tube + tube rectification front end. The LKS seems to be more sensitive to the current than is my vinyl listening.
For the record my cables are very well broken in Coincindent from LKS to pre-amp and Discovery (long) from pre to amp. Both are balanced. I have not experimented with the cable running from the LKS. I also use Coincident, but unbalanced, from phono pre to pre. Perhaps my cables roll the highs. Who knows?
Has anyone experienced this sensitivity to the current, that is changing performance at different times, everything else the same? suggestions?
