b0bb
- Oct 15, 2014
No. Yes I am one of the few commented LKS004 bass was not an issue and I am listeniing through speakers. And yes I admit the bass is coming from the speakers+room response. But I disagree the cause of "not an issue" is this. If you feel the bass is weak and thin, first please check your cables. I have used some pure silver cables (made by Lavricables, their top of the line Master series, power cord and speaker cables) and serveral interconnects from Oyaide, DH Labs. They all made the sound quality bad including weak bass, harsh high, glare etc. After I changed to good quality cables whole frequency range sound correct and no distortion. What you are doing now adjusting the sound signature of LKS004 is all based on the cables you are using. I would say the stock LKS004 is everything all right.
And my Amanero is powered by uptone LPS1.2
I do not find the LKS004 to be sensitive to cables under 10ft , I run the studio grade stuff from Canare, Mogami and Gotham. The cables are interchangeable.
LKS004 has to be compared to another DAC to bring its limitations into focus. I have the Schitt Yggdrasil and T+A DSD8 on occasional loan, both handily beat the stock LKS004 in the bass department whether it is on headphones or speakers.
Now that Amanero has addressed the Native DSD issue, I am considering getting the T+A which also uses Amanero.
I have started down a slightly different mod path for the LKS004 this time.
1)HQPlayer (HQP) converting everything to DSD512, at that high rate most of the internal DSP processing in the 9038 is bypassed, this processing is partly responsible for the poor bass performance.
2)HQP's SDM modulators are far superior to the on chip ones on the 9038 and it does a better job converting PCM-->SDM
3)Amanero native DSD mode is very close to being completely done.
Bass performance with the polysinc-xtr filters right now is slightly better than the Yggy.
To completely get rid of the 9038's processing would require DSD1024 (its internal rate), we not quite there yet.
