fewtch
- Jul 23, 2003
Darnit... black pads that look like they're similar to HD414 pads. Why do I always find out about this stuff after the fact...
BTW, anyone know what kind of dye is best for the yellow pads? Will hair coloring dye work, or does it have to be RIT? Do they actually dye black, or will they end up tan/brown?
Originally Posted by tbonner1 I use the Radio Shack 33-379 pads. I just put them right over my Porta2 existing pads. Yes they muffle the highs a bit, but it also reduces the harshness. It also reduces the bloated bass by pushing the drivers out away from your ears which is one reason why the KSC 35/75 bass are not as bad. This is a great improvement without the need to modify your Porta's or cut quarter sized holes in the pads. Slip the new pads on and enjoy, unless you are one of those people who MUST mod something. These pads also fit the Grado's and are a cheap alternative to the bowl pads to reduce some Grado brightness. Cost is under $3.00 |
