Fickle-Friend
- Apr 7, 2004
Okay, I see. Seems to be two possible reasons why this would happen. The good news is that think this is fixable. If I understand correctly when you are wearing the headphones, facing the energizer, after the Y split in the cable, you have to turn the cable over to plug it in, resulting in a twist in the cable? Mine doesn't have any twists when wear them like this.
Option 1:
You are wearing the headphones backwards, which I doubt.
Option 2:
I think this might be caused because of identical twists in the cable above the Y split on both sides. This can be fixed, I think, by disconnecting both cups from the headband and untwisting them until you can plug them in without a twist.
Otherwise, I don't think the headphones would work because of how they are wired. On my set the wire with the dashed line is closest to the back (in relation when you are wearing them) of the L cup, facing out. The solid line wire, however, is on the front of the R cup, facing inside. Does that make sense? I hope this helps. Let me know.
Thank you for your help, I followed what you said about the Y split, I managed to fiddle around with the Y split, I removed both pads from the headband, that is the culprit here. I wish they weren't removable, this issue wouldn't have arisen. I've got it finally sorted, I'll have to get used to this wide flat cable.
