adeadcrab
- Jan 30, 2008
Is this the same side you popped away from the grill?
I think the E90 is pretty decent actually. It is without a doubt more dynamic than say a Stax tube amp but the Stax is smoother. Both are pretty detailed. (compared to my Stax SRM-T1) I was actually impressed with the E90. Yes I believe any good Stax amp is better but if I were stuck with the E90 I'd be pretty ok with it.
I use my STAX compatible e-stats with the E/90x and it is a very decent driver...not really much difference between it and the STAX solid state ones to me. I do absolutely prefer my full custom Estat rig to either one, but for a generally really good sound that's easily portable, the Koss and STAX solidstate drivers work well and are more similar than different.
Great thread. Lots of info about Stax amps. Interesting comment about leaving Koss powered up all the time. Would be nice to have more info. Thanks for posting.Interesting. Does this mean you have a stax to koss adapter to connect Stax headphones to the e90? I thought a certain resistor in the Energizer was required for stax headphones. I kept the male end of my koss extension cable in case I had a reason to splice together the opposite kind of adapter. To be clear, my friend made a "Koss to Stax" adapter for me - but I haven't seen a reason to make a "Stax to Koss" adapter.
My untrained ears find the Koss esp950 connected to my Stax SRM 300 to be a big improvement in detail, layering and soundstage. The last 6 hours of listening I've had chills run down my spine many times, where I thought the E90 was great, but not amazing. This $320 purchase for a used SRM was hugely more satisfying than a $100 linear power supply to feed the E90.
I have to raise the volume of my Sabaj D5 line out higher for my SRM 300 than on my E90. With both energizers set to 70%, for the E90 my Sabaj D5 volume was at 19 out of 40. For the SRM 300 I go to 25 out of 40 for my usual listening level.
The SRM 300 has a 350v swing, and I perhaps stupidly took a chance on importing a used SRM 323A to play with. If it works (only power on was confirmed) I'll see if its higher voltage swing of 400v makes a difference. It should arrive next week.
After 6 hours, the esp950 coil whine in my right ear returned, BUT its volume was so much lower I nearly missed it. By the time I noticed it, it was gone in under 30 seconds. "Coil whine" may not be accurate, but it's my best way to describe it. I'll report if it gets louder, but I'd be thrilled if that's all I hear from now on. Previously, that noise with the E90 could make me raging mad.
Slightly off topic, previously someone had asked me where I heard that it may not be a good idea to leave the Esp950 charged all the time. I ran into post #27 yesterday looking up info on Koss to Stax combinations:
https://www.head-fi.org/threads/koss-esp950-stax-srm212.771044/page-2
Have custom STAX adapter cable made by Spritzer that came with the E/90x as it was his personal unit. I do think the STAX SRM-323S I had was better than the E/90(x), but the difference was minor in contrast compared to what the NAD C275BEE stereo amp + Mjolnir SRD-7 transformer brings to them. Actual impactful subbass is something that the SRM-323S and E/90x simply can't do, along will fuller sounding mids.
Nice unit comparisons. Your descriptions give me a good idea what to expect when upgrading. Thanks for doing these tests and reporting the results.
Anyway, my question for all of you electrostatic headphone veterans. How do you store them? I would love to hear (or see) how some of you store them.
