Ha ha that's great! I notice you have fitted the lilac Kinboofi cable to your BA10. Is that a good combination?
Lilac is a nice colour, and this Kinboofi cable is one of my first 16-core cables; somehow they came together with BA10 and are now inseparable. I did get and tried TRI Through for BA10 and AS10.
I did not find BA10 to be as cable sensitive as AS10 (different crossovers) and A10 (being all-BA at 15 Ohm and with sparkly treble, A10 served as a most sensitive IEM for cable testing).
I do prefer the cables without ear guides for the most flexibility of the fit. Fit is a very important factor for me with cables.
Then with all the cables, I hear very little difference with all of them - copper, spc, pure silver, when the resistance is less than 0.5 Ohm per wire.
@hakuzen &
@RikudouGoku have nice databases of cable measurements to consult.
Beyond the resistance measurements and the documented effect of resistance, there are hearing the difference and imagining the difference.
For the later, lilac, blue and blue-green cables are my absolute favourites for the shimmering holographicity, expanding and extending above and beyond, and nicely accentuating the positives
There are no measurements to prove any difference between pure copper and spc of the same thickness, and to suggest that OCC, SPOC are any better (and I am not even starting about graphene and palladium...)
So the nice lilac cable got the best match with BA10 for the colours, comfortable listening and overall most enjoyable listening experience
