voicemaster
I told him to try foam but he refused so ....What tips do you use on ASX?
It is crucial to find the tips that work perfectly.I told him to try foam but he refused so ....
S size tips from bgvp dn2 and m size tips like sony hybrid(two color black and green).What tips do you use on ASX?
Wouldn't it be safer to wait then and buy a 2nd pair later when the problems are worked out?Because the reviews are total opposite. So I suspect there is a bad batch or something like that because they rushed the production. So far tho my ASX and ASF sound amazing, but they do have some cosmetic problems.
Yes, I have often seen that since ASX they use the smallest nozzles, I also tried it and sat down great with themIt is crucial to find the tips that work perfectly.
I use the smallest spinfit's on all my iem's as they are the only tips that don't cause discomfort for my baby ear canals
Could be a safer bet, but also this could be the case, that the people who like them, simply like them the way they are, you never knowWouldn't it be safer to wait then and buy a 2nd pair later when the problems are worked out?
with foam tips, the headphones will stick out like bananas from the ears.
So it is worth owning both, in your opinion? I am tempted to get the ASF on 11.11 now, as I liked the ASX that muchIt is to be expected. The ASF has a more mainstream sound as opposed to the ASX. Problem is not many people have both because they both sounds amazingly similar tuning wise, but still have obvious differences. The ASX offers a more realistic depth and imaging in binaural recording which also great for watching movie (make sure don't use "headphone" setting while watching 5.1ch movies).
I did some listening comparison to CCA CA16, I listened to Amber Rubarth Sessions from the 17th ward, as it is one of my go to 'test' albums when I get new IEM.
KZ ASX blows CCA out of the water on micro detail (there were minute sounds, finger slips on strings, or breathing etc., that were completely lost on CA16), sound stage and positioning. For the cable believers, I even used the same cable for both IEM's CA16 Sounded flat compared to KZ and 'muddier' and from looking to frequency graphs online for both of them it would seem that CA16 would be slightly better at high end. ASX is just amazing on binaural recordings.
If someone has CA16, loves how they fit (ASX it a tad bigger though) ASX is a worthy upgrade, that has a good punch on a low end, but is still able to get the minute details out of the music.
Will listen to Massive Attack Mezzanine back to back next and share my thoughts on that.
If I was a YouTuber, I would be hyping the 'f' out of ASX now
For me it is.I currently have the zs10 pro with a balanced cable. Will the asf be a noticeable upgrade? Nothing wrong with my 10p, I just have upgradeitis...
Dont know what Silver Swans - Forever - House of Blood is, will have to find it to listen to now ASX destroyed CA16 on Mezzanine on all fronts.Those are the first two albums I test with. With Amber Rubarth Sessions I know immediately if the iem or earbud is wired correctly ... not out of phase. Mezzanine tells me all I need to know about the bass. Also I often use Silver Swans - Forever - House of Blood to test my tolerance to the treble. For vocals, especially male vocals, I listen to songs from artists that I have seen perform live in small venues. I know how their voices should sound.
