Some people prefer their sound signature warm.
The BLON cult's box itself says "Let Music Burn"
So we all better follow the BLON cult leader's advise in burning in our IEMs.
I know there may be better iems than the zsx at the same price point but after giving it a go, I'm sold and I've stopped looking at other stuff. I even gave up on head-fi for a while. The zsx may not be the best but it suits me just fine.Still enjoying KZ ZSX after all this time.
I've been away from KZ since it seems no news of any release (maybe due to the current epidemic, who knows), but couldn't help sharing what I saw from the PV of a song from a Japanese band:
King Gnu - Hakujitsu
I might be mistaken, but I'm pretty sure that's the KZ AS06?
X2HR are great headphones
Paragraph A will fit Moondrop Kanas/KXXS/Starfield, right? Planning on using the Starfield stock cable with my ZS7 and my current ZS7 upgrade cable with the Starfield.I made up a little graphic to show the difference between the different types of KZ cables, since a lot of people are confused on this.
Feel free to use the image when/where/how you want.
Yes it will fit but be warned! KZ pins are .75 while the standard 2 pins are .78. Once you plug it in you can't use the .75 pins anymore, it'll just fall off as it will loosen the terminals.
I guess I just got lucky then. I was using a .78 cable with my ZS7, and I just put my stock .75 cable back on it. It's holding fine with no issues. That said, this is the first time I've ever unplugged the .78 cable so maybe it's the repeated plugging that loosens it.
Yes, I agree. I'm the same way, as once I select a cable, it stays on that set for a long time. Repetitive unplugging and plugging will cause the tiny sockets in the iems and the pins on the cable to wear down. People need to realize that these small devices are NOT as big or robustly built as the terminals of full sized home audio gear, such as amps, preamps, speakers, etc. Just because an iem manufacturer gives the consumer the ability to replace the cable, doesn't mean that their product was ever designed to to accommodate multiple cable swaps. I'm sure most would say that the option is included because cables can sometimes break or fail, so designing an iem with a removable cable makes sense so as to let the customer to continue enjoying their purchase once the cable wears out. I highly doubt that any iem with removable cables was ever designed to accommodate frequent and multiple connections and disconnection.I guess I just got lucky then. I was using a .78 cable with my ZS7, and I just put my stock .75 cable back on it. It's holding fine with no issues. That said, this is the first time I've ever unplugged the .78 cable so maybe it's the repeated plugging that loosens it.
