captione
I'm pretty sure it's the female connector to the right side. I tried plugging it to another iem that can connect to the A-type cable and it works perfectly.Are you sure it's not the cable?
Try cleaning the pins using something like contact cleaner, residue build up can cause connection issues.I'm pretty sure it's the female connector to the right side. I tried plugging it to another iem that can connect to the A-type cable and it works perfectly.
Got the TRN V90 and they're not so different of a sound signature from the ZSX, though I think the V90 is slightly more sibilant up in the female vocal ranges. ZSX edges out on soundstage. A/B I think the ZSX is more forward with better clarity and also extends higher while still being controlled. V90 more flat with slightly better mids. Both sound miles better than my iBasso. Comfort & Isolation about the same. Both are great, but probably going to stick with ZSX.
I think the V90 has super annoying peaks at 10KHz, it seems like most people don't notice this. I have to EQ it down, it drives me crazy. I don't have the ZSX but the ZS10 Pro doesn't have this issue.how is the fatigue for longer listening between both ?
I might do that later, although take note that I rarely used it. Really hoping that it's just residue lol.Try cleaning the pins using something like contact cleaner, residue build up can cause connection issues.
Have you tried comparing it to CCA C12? It's honestly on my buylist, but I'm pretty torn between it and ZS10 Pro or ZSX. I just wanna complete my hybrid collection and I want something that isn't too much on the bass and too hot for the highs.Got the TRN V90 and they're not so different of a sound signature from the ZSX, though I think the V90 is slightly more sibilant up in the female vocal ranges. ZSX edges out on soundstage. A/B I think the ZSX is more forward with better clarity and also extends higher while still being controlled. V90 more flat with slightly better mids. Both sound miles better than my iBasso. Comfort & Isolation about the same. Both are great, but probably going to stick with ZSX.
How does the bass compare? (Quality and quantity)
I have the ST1 coming soon. What do you think of it?add the qkv vk4 to the mix, had them forgotten
that's the trio infernale: TRN ST1, KZ ZSN Pro, QKZ VK4 - regular earphones from the supermarket and the default electronic store don't have a chance with cheap upgrade cables
(edit: ZSN Pro, there doesn't appear to be a ZST Pro)
I’m assuming you took to them with a blow torch.Just so you know: the Faaeals have some inherent issues that are very hard to work around (stabbing mids, driver flex, no treble), and are prone to spontaneous combustion.
Ya got meI’m assuming you took to them with a blow torch.
I actually don’t mind my hibiscus. They fit really well and have a different sound that’s different to many of my other iems. Treble is a bit less intense and are very relaxing to listen to. A bit more mids and bass orientated. I don’t find the mids stabbing.
I actually pick them up before my BA5s. Go figure!
whatever eases the pain of buying a set of iems you don’t likeYa got me
I probably just got a defective set. Or defective hearing.
