The $50+ releases of CCA and KZ are good enough even when paired with lower sources like the Walnut or Zishan for me. So much so I'm considering getting rid of a lot of my TOTL gear. My $50 KZ7 sound better than the older TOTL universals in th $300-400+ range from yester year about 5-10 years ago (ie Audio Technica CK10, Ultimate Ears TF10, Westone W3, Westone UM3X, Shure 535, Sennheiser IE8), and I want to play with my car more these days for a while.
There is some variation between units with the ZSX. My original black/silver version sounds great, but the blue/gray version sounds ever so slightly edgier and peaky in the treble, even after extensive burn in. It's unfortunate but isn't surprising given the sheer number of drivers in the iem, especially at the price point. The reviews I've seen that describe a fatigue or peakyness in the treble sounds like what I've heard with my second unit. My first unit sounds more balanced and is fatigue free. Maybe I got lucky on my first unit or maybe my second unit is an outlier, but my first pair sounds good enough that I'm probably selling my V90. It would have been a harder pick between the two if my only unit sounded like the second one
I would like to thank the KZ community here for their help and advice through the purchase and usage process!
After receiving the ZSX for a couple days and comparing it with my Shure SE215m+ (its not a great comparison but that is the only IEM I had before) here are my thoughts:
TLDR: ZSX > SE215 in instrument separation, clarity, and bass but may need other tips for a better fit for smaller ears (YMMV). Portability + Commute = SE215 / Critical Listening = ZSX
Setup:
KZ Gold-Silver mixed upgrade cable + NewBee Foam tips (IEMS fit nicely in a Shure case) with Macbook 12” as source (Spotify)
Size Comparison:
Fit + Comfort:
Having small ears, fit was not that great with the stock eartips or starline tips as it would sit on my ears at an angle (ex. The left iem would sit at an angle “\” if the “|” represented the iem)
With the NewBee foam tips, the fit was more secure and sat closer to my ear.
Sound:
Briefly commenting on the sound since I am not an audiophile at all. The instrument/voice separation, clarity is way better than the SE215. Bass is tight and the “kick” is better compared to SE215m+.
Pros:
Gold-Silver cable is very flexible, lightweight, and is very easy to untangle if tangled
Sound is great compared to SE215
Isolation is fairly good with foam tips
Cons:
Stock Brown KZ Cable gets tangled easily (would recommend changing the cable if you want a tangle free experience)
Required foam tips to have a better fit (stock and starline tips did not fit well)
Notes:
I had a slight hiss on my ZSX, I was able to reduce the hiss by increasing the system volume while reducing the application volume (ie. Spotify volume control)
NewBee tips appear to shed black particles when wiped down with a cloth compared to Shure foam sleeves
wonder what material Shure Sleeves use to make them so durable. I have had them since 2016 and never had to change the foam tips
Would recommend pushing the foam tips as in as possible (i pushed it until i could not see the shiny metal) to reduce the "tunneling" effect that may be sometimes heard on foam tips
Setup:
Size Comparison:
Fit + Comfort:
Sound:
Pros:
Cons:
Notes:
I use spinfit CP 100 with my KZ ZS10 Pro and it fits 100%. Never used the other 2 models (CP500 or CP155) so I can't advise whether they will fit or not.
Spinfit CP100 gives better comfort and isolation than stock tips. It does make treble a little bit increased.
just found out what the Zs10 Pro does better than all of my other IEMs, it works really great for playing games on my PS4. it's really spacious, conversations are clear, and pin-pointing sound is easy.
it's almost similar to my Kanas, but the Kanas has a more "analog" sounding mids and upper treble, making the ZS10 Pro sounding more sparkly and cleaner. for music though the Kanas is still better for my ears
