dondonut
- Jan 6, 2017
I already have one of these that works really well and generally works better and is easier to use than the KZ model. I think until there's a cable model that has a good antenna and lasts for more than 2-3 hours I'll stick to it.You can easily add a shirt clip to the KZ Bluetooth cable. The shirt clip just attaches to the wire. You can also run the wire behind your neck vs in front.
BTW, have you seen the new TRN BT20? Totally wireless.
Mine hasn’t arrived yet, so I don’t know how well it performs. Only what is in the product description and photos.
Hooray, you make graphs too, I love graphs!@Sylmar I absolutely agree. Here's my ZSN review. Enjoy.
https://primeaudio.org/kz-zsn-earphone-review/
I'm looking to buy the KZ ZSN tomorrow, but i need just one info to decide which colors would fit best for me.
Does the brushed alluminium surface (Black and cyan) feel a little "bumpy" when you try to scratch it with your nails or is super smooth (like the purple one)? I get tingles everytime i touch a brushed alluminium surface and would like a really smooth surface, like glass or stainless steel.
Great review, crabdog!@Sylmar I absolutely agree. Here's my ZSN review. Enjoy.
got my ZSN today. bought on 11.11 from official KZ store. pretty fast shipping to Germany.
I don't want to write much about the sound, because they need some burn in time. The only thing I noticed is that they are super efficient. To efficient. They are really loud on my OnePlus 3 with just 50% Volume (the Takstar 82 Pro take like 80-85% for the same volume. And Superlux HD 668-B are not at all load with 100%. Also my old Havi B3 Pro are just on medium volume @ 100%)
They have such little resistance that with my OP3 I even have a small background hiss noise which I have not noticed with other headphones until now.
I have yet to try the ZSN with my hifimediy SABRE ES9018 DAC. But I'll wait some days till they are burned in enough. And the ZSN are anyways not for desktop use but more for mobile use, that's why I care more about the performance on my phone.
So I thought maybe the BA driver is wired in parallel with the DD, so I took one side apart. First I thought it was Torx , but its not (see 2nd picture)
The crossover seems to be soldered on to the dynamic driver, and I can not tell 100% if both drivers are wired in parallel or series.
Because the are "to efficient" I would rather mod the to series wiring (If they are wired parallel)
I will update on sound quality after some days.
But overall I am really happy already
+1 I was surprised to see the jack screwed down as well! ...Incredible value! ...And the crossover is a plus, too!Thanks for the photos! Very clear and closeup - so helpful
As far as I can tell, the drivers are wired in series not parallel.
I am impressed at how clean the assembly work is inside. No glue glopped everywhere. Even the soldering work looks quality. And the jack is screwed down wOw!
BTW that 5-point driver is called a pentadriver, and it used in Apple products.
