First thing is to make sure there is nothing wrong with the earphones themselves. Change the sides and see if the problem persist in the same ear or if it migrates to the other ear, i.e., if the problem lies with the earphone, it will migrate to the other ear.
If the issue is an anatomical difference between the ears, try using different tips, tip sizes and different insertion schemes. Start by inserting the IEM with your mouth opened and your jaw relaxed, and your head tilted towards the front or the back. If this doesn't work, time for tip-rolling.
There are several options, from double or triple flange to foam tips. I would try ordering a cheap box of faux-comply foam tips and see if they solve your problem. Foam tips adapt the best to the ear canal, contributing to a better seal. Otherwise, if the problem is lack of stiffness in the tip, some Sony hybrids could be the solution. There are also cheap faux Sony hybrid tips which are made to a similar material and design. You will recognize them by the colour scheme in the nozzle - red - XS, orange - S, green - M, blue - L.
I'm sure it's not headphone's fault as i even tried with my memt x5 and same thing happens, and the same thing happens even if i try to swap left and right channel
Anyway i already tried but right ear is something annoying
I mean i listen to music in a good way but there's always that little difference between the ear canals that is really annoying.
If i put medium/large tips on the zs6, my left ear is little and i have to pick my ear and pull up while opening mouth in order to pinch it into my ear canal, then it works flawlessly. On the right side, the ear canal is bigger and tips tend to let air pass i think, the problem is i tried every kind of tip but it seems like there's something different even in terms of deepness shape, i mean maybe there isn't just this difference in the ear canal, but more than one if i could dig into my ear and discover it
Then in the right side i feel like i have a closed style in ear, in the left side it seems i have a open back design iem.
