- Thread starter bhazard
Slater
Because you catch the KZ fever and it’s all downhill from there (for your wallet anyways).Thanks.
Why stop following the thread?
Slater
More BAs don’t always = piercing highs. It all depends on the drivers used, the design, tuning, etc.Dammit! 4BA! Why not 3+2? Or it's kinda "we need more piercing highs"???
The Magaosi K5 is a 5BA, and it’s a fun, engaging IEM with lovely highs.
I do think KZ needs to branch out and try other BA models. They keep using the same 2 over and over, which is one of the reasons why their last 4-5 offerings sound fairly similar to one another.
CoiL
Member of the Trade: Wood Audio Accessories & Modifications
or... You finally manage to save up from buying cheapos and jump to next tier of IEMs (which, IMHO, is much more sensible!). I just am into modding cheapo iems for learinig and testing different things
Cruelhand Luke
- Jun 23, 2016
- Location
- Morro Bay, California
- Website
- thesoundword.wordpress.com
because otherwise you are going to turn into one of the maniacs around here with a dozen sets of KZs!Thanks.
nadezhda 6004
What the name for the adapter and specs to look for?Imo adding resistance is the better way to go with the ZS6 - either by using an adapter or by soldering the resistors directly into the cable.
Just look for "impedance adapter". @hakuzen has posted some before/after measurements in this thread. I think I have as well.What the name for the adapter and specs to look for?
75 Ohms is quite common. Should be available on Penon Audio, ebay, AliExpress, ...
WalterTorino
Yeah, I guess its gonna be interesting if KZ will do some experiment with another drivers.More BAs don’t always = piercing highs. It all depends on the drivers used, the design, tuning, etc.
Btw, can you recommend any model from KZ with good deep bass but with the same detailed mids and highs? Is only ZSR close to it?
Wow... Magaosi looks great and i believe it sounds great too. But it's way more expensive than i can afford for now...
I guess $100-150 is a maximum that i can spend.
+1.More BAs don’t always = piercing highs. It all depends on the drivers used, the design, tuning, etc.
There are cheaper Chinese BA drivers nowadays (bellsing/estron) with a similar design from Knowles which can be more interesting for KZ projects. Even for DIYers trying to learn how to tune or play with crossovers and etc... Someone made this list which can be helpful: https://docs.google.com/spreadsheets/d/1gFl8N3JvOi8HQrZbn8zxRMClBfxPpoh4XvQlzPyCki0/edit#gid=0
I always thought the idea of double BA at the nozzle would be more suitable for something like the TWFK's design since it has only one bore linking two BAs, thus it's easier to tune and you'll get all extension and avoid frequencies canceling each other due to possible phase problems or alignment problems might causing minor channel imbalance if you imagine how hard is keep that in high demand of production.
Btw, my perfect KZ would be ZS3's shell all black matte + ED9 filters options design or ala LZ A5 and configuration similar to DN2000 (DD for bass and TWFK for mid/treble). They have all knowledge to create something like this and I wouldn't mind paying the mid-range ($50-100) category for it.
NeonHD
Cause you'll be infected by the KZ disease and you'll never stop craving for the latest KZ earphoneThanks.
Tyler Durden
- Jun 18, 2009
- Messages
- 51
- Reaction score
- 11
I think I've had all of the KZ earphones in my basket so far!
Shall I stick with the ES3 and ZS5 as recommended above?
The ZSR triples look good to me!
WalterTorino
I think you continue to spend money on headphones just because you have not found the right ones yet. Maybe better to have a look on another manufacturer? To buy more expensive ones but to stop on them and finally be happy with the sound you have? Without any "or"I think I've had all of the KZ earphones in my basket so far!
The entire black nozzle of my left zs5 v2 came off when removing a tip. I reattached it with tape but the sound has changed. I still hear the high frequencies, but much quieter. Maybe I should block one BA in the right piece like Slater described to see if they match?
Disappointed with this issue, it's the first real build quality problem I've had with any of my KZ models.
I've had the same issue with a ZS5 nozzle which came off and I fixed it with cyanoacrylate glue. I think that now it sounds exactly like before.The entire black nozzle of my left zs5 v2 came off when removing a tip. I reattached it with tape but the sound has changed. I still hear the high frequencies, but much quieter. Maybe I should block one BA in the right piece like Slater described to see if they match?
IamMe90
- Mar 15, 2017
- Messages
- 206
- Reaction score
- 165
Anyone else really disappointed in the ZS6? I find them noticeably worse-sounding than the ZS5. The treble is ridiculously hot. I appreciate the improvement in housing material, but jesus, a lot of tracks are ridiculously strident/harsh sounding out of these things. I am definitely not dealing with a phase issue or anything like that.
