CoiL
Member of the Trade: Wood Audio Accessories & Modifications
Can you give the link or post the picture here. I cannot find them on twitter.
Edit: Found them
screwCK ZS6 - I WANT THOSE!!! ;P O_o
Edit: Found them
Edit: Found them
Edit: Found them
1) I used brass nozzle from ED9 and did drill-phase nozzle edge into "trompet"-like.
2) nozzle length should be slightly shorter with new nozzle and inner diameter should be larger than stock plastic nozzle. Nozzle material plays quite big role @ highs sparklyness.
Bigger nozzle inner diameter "lets" details through better and evens up FR (bass "pulled back" little) but breathing ports "enforcement" helps to "raise" bass punch/slam littlebit.
ATR has different driver inside for sure (I have opened many) and so far there seems to be only 1 revision of ATR. ATE 5th gen has red shelled driver with tiny "tube" at shell in front of driver, ATR is blue without any "tube" but same size hole.
If source is snake oil to You, then You miss quite a lot. The better the HP, the better effect source actually has (because HP is able to deliver all that`s been fed).
What source and files are You usually using? What tips did You use with ATE?
But regarding ATE - You must have had faulty unit. ATE sounds nothing like You described.
Thanks! Will try to get one.
It comes in 4 colours.
Seems no matter what design they choose someone is going to $%^& about how it looks like X or Y from another brand.
I'm looking forward to the ZSR after being quite disappointed with the ZS6 KZ...no more ear piercing highs please.
Well, at least I could enjoy the ZST and ZS5v1 with foam tips...but not the ZS6, even with foam tips. I really was trying very hard to like it but I gave up after modding it with some foam filter stuffed into the foam tips...still no go. I also tried the 75ohms adapter but it sucked the life out of the ZS6...sigh.It's the KZ house sound
