Oct 31, 2017 at 2:25 PM Post #24,436 of 63,834
Lack of sub-bass extension I can see on the Zst but lack of bass as a whole I don't unless he just got a faulty pair. Usually mid-bass is very pronounced and the Zst is a pretty deep V shape sound signature.
Oct 31, 2017 at 2:47 PM Post #24,437 of 63,834
About the Xiaomi Hybrid Pro which I own vs just the hybrid which I don't own... I find that I like the fit when wearing them over ear but in the correct ear. They're designed to be worn cable down and people typically swap left for right when wearing a cable down style as over ear but I didn't like the fit that way. There are comfort complaints in the Xiaomi hybrid pro thread. Like the ZS5 (and ZS6) there is a port on the facing the ear side that can be blocked or partially blocked to add more bass. Either have plenty of decent that goes pretty low but isn't flabby and loose bass, especially depending on modifying the small port hole. In comparison I find the mids and highs to feel smoother and less piercing but less detail, less differentiation between instruments compared to the KZ products. So comparable but different IMHO.
That sounds right up my alley. I should have ordered that instead of the ZSE. Seems like it would be easy to recommend.
Oct 31, 2017 at 3:01 PM Post #24,438 of 63,834
Some samples of sources (no coupling caps, low output impedance) power pairing with KZ ZS5 v1
(note: voltage and current are RMS; dB are SPL, except in graphs)
reminding ZS5 v1 and ZS6 impedance and sensitivity..
ZS5 v1 (4.8Ω @ 1kHz). sensitivity: ~122 dB/V (99 dB/mW).
ZS6 (14.3Ω @ 1kHz). sensitivity: ~127 dB/V (109 dB/mW).
Benjie S5
(DAP)
Volume steps: 30
ZS5 v1: maximum volume setting with "low" distortion: 10 / 25mV / 5.20mA / 90dB peak :heavy_multiplication_x:
ZS6: maximum volume setting with "low" distortion: 15 / 78mV / 5.38mA / 105dB peak . :heavy_minus_sign:
JDS Labs C5D (USB DAC+amp / amp)
ZS5 v1: maximum volume setting with "low" distortion: 117mV / 24.4mA / 103dB peak :heavy_minus_sign:
ZS6: :heavy_check_mark:
SMSL iDEA
(USB DAC+amp)
Volume steps: ~20 (2.5dB/step, except first steps) .
ZS5 v1: maximum volume setting with "low" distortion: ~14 / 257mV / 53.6mA / 110dB peak :heavy_check_mark:
ZS6: maximum volume setting with "low" distortion: ~17 / 618mV / 43.2mA / 123dB peak :heavy_check_mark:
xDuoo X3
(DAP, rockbox)
ZS5 v1: maximum volume setting with "low" distortion: ~75% / 310mV / 64.6mA / 112dB peak :heavy_check_mark:
Considering this info, many sources provide enough power with low distortion to drive ZS5 v1.
The only ones which can't drive them properly are cheap DAPs like Benjie, or many smartphones, or weak amplifiers (and they are just fair with ZS6).
JDS Labs C5D can reach acceptable sound level (~103dB peak, let's say 90dB), but not enough if you like very loud volume.
SMSL iDEA / Sabaj Da2, and XDuoo X3, don't have any problem to drive ZS5 v1.
Oct 31, 2017 at 3:07 PM Post #24,439 of 63,834
Benjie S5
(DAP)
Volume steps: 30
SMSL iDEA
(USB DAC+amp)
xDuoo X3
(DAP, rockbox)
Thank you very much, mate!
Oct 31, 2017 at 3:08 PM Post #24,440 of 63,834
The problem I found when wearing up an NOT swapping the channels is that it muffles the sound in a weird manner). The reason for this is that the nozzles are angled, so when you wear them up AND swap the channels, the nozzles still point in the correct direction (ie towards your ear drum). If you wear them up and do NOT swap the channels, the nozzles angle the wrong way (away from the ear drum).
Sure, I could still hear it, but it was so much clearer when they were angled the proper way. I guess it was reflecting off my ear canal on the way to my ear drum, which is what was causing the muffled sound. Maybe your ear canals are angled/shaped differently, which is why it sounds OK when you don't swap the channels?
If the 3.5mm jack ever goes bad, I was planning on reterminating them with the channels swapped in the plug. That way, I can wear them up and swapped (for fit), but the L/R channels will actually be correct.
Oct 31, 2017 at 3:14 PM Post #24,441 of 63,834
Benjie S5
(DAP)
Volume steps: 30
SMSL iDEA
(USB DAC+amp)
xDuoo X3
(DAP, rockbox)
I can verify that the ZS5 v1 sounds great with the xduoo X3. It sounds significantly better when the FiiO E12A Mont Blanc is added into the mix. But I often roll without the amp, and in those cases I am more than happy with the sound of just the X3.
On that same note, I despise how it sounds straight out of my iPods (Classic 5.5, Nano 6G, & Touch 5G), as well as my iPhone SE. Very harsh and thin, with a lot less bass.
Oct 31, 2017 at 3:29 PM Post #24,442 of 63,834
You've perhaps seen me commenting in different threads about my troubles finding tips that fit whatever IEM comfortably and gave decent sound so I wouldn't be surprised in the least that something about my ear canals are different from typical. When I get a good fit and seal the Xiaomi stick out my ear in a very odd way so I understand what you mean about not getting them to fire down your ear canal but into the side. That's why I made sure to mention that at least some other people had fit issues so as not to give the impression that upside down and not swapped was a solution for everyone. Both brands suffer from a fit and comfort issues in their choice of an atypical design or shape.
I just started some serious listening to the SoundMAGIC E10M I got from Massdrop for $21. I don't know typical retail but they're surprisingly full bodied sound. Standard dynamic driver instead of a balanced armature hybrid so a different sound signature but its a possible substitute @kokakolia
Oct 31, 2017 at 3:45 PM Post #24,443 of 63,834
Yeah, pretty sure I remember reading you having issues with tips (foam tips getting squished I believe).
Anyways, I'm glad they work for you as-is. I wish I didn't have to swap channels to get mine to fit and sound good. Just shows you how different everyone's ears are.
BTW, I used to have the SoundMAGIC E10. I agree they are really good for an older IEM. The cable is very fragile though, and mine didn't last long. Hopefully they revised it or yours lasts longer.
Oct 31, 2017 at 5:50 PM Post #24,444 of 63,834
About the ZS5 (v1) and the differences between music types/recordings.
Yesterday I was listening to the Beach Boys' Pet Sounds. Amazing studio work, great mastering, with the ZS5 you can really listen to all the technical work that went on the making of that album, and still appreciate the music.
After that, I was lusting for some Red Hot Chili Peppers and started listening to 1999's Californication. Well... This album is musically grand! But it is also well known for the extreme dynamic range compression. And with the ZS5, you can actually hear the compression. The result is a total mess. There is no texture, no instrument separation. From time to time, you can listen to the way compression was jiggled, for instances in some of the Chad Smith's drum passages, when the drum work comes up front and is distributed between channels, to return again to the same old messy sound.
Resuming, I think the ZS5 is great, but not recommended for those who mainly listen to ill-mastered records that suffer from the "loudness wars" dynamic range compression extremes. The ZS5 loves jazz ensembles, old pop and classic rock, prog and classical music. But when it comes to modern rock and pop music with too much compression, it's a no-no! I think this might explain why some people find the ZS5 to be so different between some musical genres... it's not the genres, it's the loudness! They are too good for ****ty masterings!
If you can find it, there is a version of Stadium Arcadium around that was mastered for vinyl. Night and day difference, although there is still a bit of audible distortion on bass drum hits in places. That version removes most of the torture of listening to the great music on the album. The hack job mastering the album for CD should be a criminal offense.
Oct 31, 2017 at 7:17 PM Post #24,446 of 63,834
I don`t remember who here had "issue" with ATR and ATE sounding bad but I got my latest pair of ATR + ATE and I absolutely love them.
ATE seems to be same as my last 5th gen ATE with red drivers inside, golden "grills" inside shells, gold/black metal cable reliefs, golden cable weights, code of shell is RQ:018NBM.
Didn`t do A-Bing with ATR atm but with short listen I can tell they are almost same sounding as ATE but with less bass and slightly more clarity/highs details and slight soundstage difference.
But I absolutely love the sound coming from ATE 5th gen (red nozzle grills removed + wide bore silicone tips (tips edge on level with nozzle) ).
Still my #1 dynamic IEM from KZ, especially with FF-modification. Atm, listening Lucid Planet - EP & Seven Impale - Contrapasso 16/44 FLAC, just great SQ - hard hitting tight detailed bass, liquid detailed mids with weigth/warmth/naturalness in vocals and smooth but detailed highs, great soundstage with good frontal depth and stereo separation and layering. Just great.
I think some ppl here hating ATE & ATR have issue with proper quality source, amping and file quality or just have very different SQ preference.
For information, I use HW&FW modified DX50 for those impressions.
Littlebit amping, removed red nozzle grills, custom cable, open back grill-mod, breathing hole adjustment and nozzle change these turn into "mindblowing" DD that slap ass of many cheap hybrids out there imho belive it or not ;P
Oct 31, 2017 at 7:33 PM Post #24,447 of 63,834
Listening to Californication right now. You're right, it is a compressed mess - it sounds like a 128k MP3 rip. I always thought it was the lossless rip I did (sometimes settings can cause wonky results), but I listened to the CD source and it sounds the same.
Man, what a tragedy. I hope someday they release a remastered version (and I mean a PROPER remaster, not some of the junk remasters that are simply money grabs).
Oct 31, 2017 at 7:42 PM Post #24,448 of 63,834
Totally.
My modded ATE (same mods as yours minus the nozzle tube change you did) is one of my top single-DDs in my collection. It was only recently bested by the UiiSii CM5 in overall single dynamic performance, but I still think the modded ATE sounds more natural. It's the next best thing to being live in concert.
Simply amazing for an $8 IEM and 15 minutes worth of mods.
Oct 31, 2017 at 7:48 PM Post #24,449 of 63,834
Totally.
True. Only other thing I have same way close to "live" natural sound is my desk setup (modified Aune T1 with Siemens E88CC goldpin) + Fidelio X1 (custom cable).
While I enjoy KZ ZS5v1 very much, putting modified ATE into my ears makes me always smile and drown into music without thinking/nitpicking on SQ :)
But I should try UiiSii CM5 then too, if You say it is so good :wink:
Oct 31, 2017 at 7:59 PM Post #24,450 of 63,834
What wide bore silicone tips are you using BTW? The KZ turbo/whirlwinds? Or something else?
I think the 2 biggest problems with the ATE that are likely the source of people's dislikes are 1. the terrible stiff gel foam tips and 2. the nozzle screens.
