Already tried that, and the small piece of foam slips around when I try to insert the tips. Ended up just shoving down the foam instead, just like @chinmie did. Oh well, I think that will do for now.Just do a bigger circle of material. If the tips grip tight the nozzle, the material don't move.
- Thread starter bhazard
Do it bigger, envelop the nozzle, keep it with the fingers, put the tips over it.
try making rectangular strip, as wide as the nozzle 's diameter (or a little bit bigger is okay), but give enough length so that you can hold it with your fingers before inserting the tips. it might be tricky in the beginning, but it's doable
Sebilion
Does anyone know a good cable for the ZS6? One that is better than the original one?
If you want to know if an upgrade cable change something, you better know that they are mostly needed for take away the microphonics, those strange noises that you can feel on sound when you hurting the cable. Sound-wise the upgrade will be marginal, there is a lot of other things that can change more the sound.Does anyone know a good cable for the ZS6? One that is better than the original one?
maxxevv
Would mind providing the link to those the only one I found at that price were the carbon fiber one and I don't want that one.
I got them from here:
https://www.aliexpress.com/item/New...32703512553.html?spm=a2g0s.9042311.0.0.ROxuSy
But they seemed to have increased the prices in anticipation of 11.11. I paid about US$2/ 2 pieces.
bsoplinger
They're 2 for $2.21 so that's still close to $1 apiece.I got them from here:
ReBreaker
- Jul 8, 2016
Anyone hesitate about to grab the ZS6 red for 26 bucks from GB now or wait what will show up 11.11? That's the question. The lower the price the better for me at the moment coz I'm still firing up my modded ZS5...
oyobass
I ordered a green one Wednesday, along with a carbon ZST. I guess the price was 'good enough' for me at 26.00 and 9.00 respectively. I tend to agonize over saving a few pesos here and there, so just buying them now at a significant discount was a freeing experience, lol.Anyone hesitate about to grab the ZS6 red for 26 bucks from GB now or wait what will show up 11.11? That's the question. The lower the price the better for me at the moment coz I'm still firing up my modded ZS5...
Add to that the likelihood of order processing and shipping may be slowed to a crawl on and after 11.11 and I figure I have a win-win situation...
lowendtheory77
Has anyone done a comparison between the ZSE and the ZS6? I’m curious about the ZS6 but the ZSE has taken my heart. To my ears, they sound like the iem equivalent of my grado SR80’s and only for $6!!!
xrk971
Member of the Trade: XRKAudio
Where are you guys getting the ZS6 for $26? Oblivious here.
Gearbest with discount codes but they are only a short term code. Gerorge from gearbest puts the codes in another thread.
https://www.head-fi.org/threads/201...uedio-f2-62-99-bluedio-te-8-99.832367/page-30
kokakolia
- Aug 14, 2013
Uh.... okay! Glad you like em!
They are source sensitive, as to me they are more precise with my Fulla than my portable rig, but maybe @lowendtheory77 say it just thinking about the signature.Uh.... okay!
Anyway... have you try to EQ them a bit ?
