IamMe90
- Mar 15, 2017
So I've got:
-Spiral dot, spinfit, and the starline ear tips;
-AK Jr, fiio x3ii, and Samsung galaxy s6 as source options (try to avoid using the x3 though since it glitches up all the time a need is out of warranty) ;
-and a fiio e12 for external amp.
I've been playing around with figuring out the best sounding combinations for my zs5. So far, I'm enjoying unamped AK Jr with spin fit tips the most. Sounds awesome for some reason the spiral dots really don't seem to work well on the zs line to me (both 5 and t). The small star line tips make the zst sound great but muddy up the sound of the 5 a bit. Weird how the same tips can have such different effects on different IEMs lol
EDIT:
Okay, sober me reversed the polarity like you suggested and yeah, it works fine now! Using it with my ZST currently (will test with ZS5 in a bit), not sure I notice much of a difference other than perhaps a bit more clarity in the highs, like you mention. But glad it's not a total piece of garbage like I initially thought lol
EDIT:
I am pretty much sure it's just the silver cable, the simplest explanation is the right one. I tried as much as I could to isolate which side of the cable is reversed, but this is difficult as either of the options sounds correct to me and if I'd had to choose one that is wrong, it would be left. Try to plug left one reversed and right one normally with the silver cable. I can hear some improvements to the sound in the upper frequencies compared to regular cable (maybe less dynamic overall), and I truly wanted to hate this cable and not use it, so I am not biased towards it in that way. It's definitely only worth for the looks/durability, otherwise, I would never get it for sound. Perhaps it has slightly different impedance compared to stock cable and it manifests with ZS5s which are already very source sensitive and require more power than expected.
